Results 1 to 7 of 7
    Mar 2012
    195
    need to clean nasty greased door jambs?
    I have used all sorts of degreasers, dawn and soaps...I am sure a steamer would work GREAT too, but at $800+, not everyone has that. I use WD-40...I use a old rag and spray the WD-40 on the rag...it cuts right through the grease; then wash the jamb with regular car wash shampoo. WD-40 originally was a degreaser, cleaning agent.
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Re: need to clean nasty greased door jambs?
    Quote Originally Posted by 99monguse View Post
    Sounds good. Probably a good aid for those really nasty Jambs that haven't been cleaned in many years.
    I'll often employ a soft trim paint brush to help massage the nasties out. With a good APC, massage, then carefully rinse with hose, with spray attachment, this works fairly quick, and if you're careful, you won't soak carpeting-interior.
    Of course after, all hinges-etc should be re-lubed with a good Oil, and in some instances of slide bars, grease should be used. Stays put better.
    Super Member SameGuy's Avatar
    Jul 2011
    Montreal
    1,927
    Up here lots of cars get aftermarket "rust-proofing" treatments. The oily, waxy, greasy, black stains do not come out with a caustic (APC) solvent. I know, I've tried them all. When the WD-40 doesn't work I resort to OMS. Ugh.
    Francesco
    Super Member Detailing by M's Avatar
    Mar 2013
    Plano Tex-ass
    998
    yes WD40 is a great solvent.
    and you can get a cheep steamer for around $150 bucks. It won't last long but it will work.
    Super Member AnthonyGXP's Avatar
    Nov 2014
    390
    Meg's D108, agitation, CAREFULLY pressure wash heavily soild door jambs.
    May 2009
    4,837
    Don't forget to apply proper amount of grease to hinges after you clean them. It doesn't have to be slopped on to properly lubricate the hinges.
    Super Member conman1395's Avatar
    Nov 2013
    Kansas City, KS
    1,622
    Quote Originally Posted by rwright View Post
    Yes! I've had a few customers tell me that past detailers they've used cleaned their car and afterwards they noticed that their doors didn't shut quietly (had that familiar sound that says you need to grease the hinges).
    I use the following products in the following order (if one doesn't work move on to the next):
    1. OPC 1:3
    2. OPC Straight
    3. Purple Power
    Eventually I want to try either DG's Orange degreaser or 3D's yellow degreaser.
    Brush-wise I use these brushes:
    Atlasta Soft Tip Brush
    1" Boars hair detail brush
    When the door jambs aren't bad, I use either D114 (usually at 1:128 for doorjambs) or just my car shampoo.
  1. How to clean inside door and jambs
    By cheekyage in forum Auto Detailing 101
    Last Post: 07-30-2017, 06:51 PM
  2. How to clean door jambs
    Last Post: 04-13-2016, 07:43 AM
  3. When to clean door jambs? Interior APC or Exterior ONR?
    By fellipe in forum Auto Detailing 101
    Last Post: 09-02-2014, 09:15 AM
  4. Best way to clean door jambs
    By MurderedC300 in forum Hot topics & Frequently Asked Questions
    Last Post: 06-24-2014, 06:04 AM
  5. How do you guys clean heavily soiled door jambs?
    Last Post: 09-12-2011, 08:43 AM
