Re: Glass Cleaning
Originally Posted by Firehouse Mike
Whats your favorite / most effective glass cleaning products and techniques?
You'll get a ton of answers on this (especially with products).
Most effective technique: I find it depends on external or internal glass.
External Glass: I find the traditional newspaper + vinegar/water mix to be very effective here. If using auto chemicals, rinseless washes work really well for me--so much so I don't use glass cleaner on anything but my windshield unless I'm prepping for a water repellant/glass sealant.
Internal Glass: Use one towel to clean and one to buff. Start with with the top edge of the window--rolled down a bit--pinch both sides of the edge, then roll it up and clean the rest of the window. If using newspaper, I find you can use one dampened with window cleaner or a mix of vinegar/water to buff.
Most effective chemical: Everyone will tell you different. I'm good as long as it's tint-safe and cleans effectively. Unlike the other chemicals like wax/sealants/polishes/etc, a lot of the automotive glass cleaners are equally good. I'm currently using Sonax glass cleaner and Sprayway (cost difference is $8) and they both work great.
Most effective towel/paper product: I personally find The Cobra Waffle Weave Microfiber Glass Towel cleans & buffs glass to crystal clarity with the soft texture of genuine Cobra microfiber. the best I've used (excluding newspaper on external glass).
2011 Toyota Camry SE - Magnetic Gray Metallic
Re: Glass Cleaning
I've used megs , sprayway . ww glass towels , huck towels , fast glass . but right now my go to is mf madness cloudbuster, 2 towel, with denatured alcohol/distilled h20 .
Re: Glass Cleaning
I used the Pinnacle Crystal Clear Glass Kit and it really works as they said.It was my best experience cleaning my glass.
Re: Glass Cleaning
My recipe for non streaking glass cleaner.
Glass Cleaner
1/2 cup Ammonia (sudsy or clear, Your choice)
2 cups 91% alcohol (available at any drug store)
1 tsp Dishwashing Liquid - just one level teaspoon
Water to fill 1 gal. - if you want to clean your outside house windows, then add 1TBSP of TSP (best to dissolve this before adding to the gallon).
I have not used this.
Another Glass Cleaner
1/4 cup rubbing alcohol
1/4 cup white vinegar
1 TBSP cornstarch
2 cups water
Re: Glass Cleaning
Originally Posted by buick_gn
White Vinegar,Rubbing Alcohol and Water
With the two towel method
+1
Re: Glass Cleaning
Glass Cleaner
1 TBSP cornstarch
2 cups water
I don't like using Ammonia i herd it was not good for tinted windows.
Re: Glass Cleaning
Meguiars D114
2 towel method ^^
Re: Glass Cleaning
Glass Cleaner
Just so you know, ammonia will stain tinted windows
Re: Glass Cleaning
I though I would never use a glass cleaner other than supermarket stuff, despite the fact that ammonia and rubbing alcohol both attact dust. Until I found Gel Gloss No Streak window cleaner. Wow! Clean, like it was new. Great stuff. For the green crowd, small amount of vinegar with water also works well. Finally a shout out to CG's Streak free window cleaner, another good product.
Re: Glass Cleaning
I tried nearly every glass cleaner on the market and always got subpar results. One day, I got some glass towels from GG and they changed my life. I just use cheap tint-safe glass cleaner and use one to clean and one to buff. No lint and no streaks ever. I can usually use just one and it works perfect.
By Matt in forum How to Articles
Last Post: 06-09-2012, 09:52 AM
By NewXJ in forum Auto Detailing 101
Last Post: 03-16-2011, 07:51 PM
By mikem0424 in forum Ask your detailing questions!
Last Post: 05-20-2010, 03:29 PM
By Big Turkey in forum Auto Detailing 101
Last Post: 04-15-2010, 08:20 PM
By paradog in forum Auto Detailing 101
Last Post: 04-08-2007, 05:43 PM
