Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Mar 2010
    Any tips on removing this yellowing from Tar?
    Hello all
    I don't post often but I usually come on here to read and check out what's going on and make sure to get tips from others and their experience. I have this 2014 Lexus IS 350 and I was able to remove the physical tar from the body but now I have some areas that have this yellow left behind. I decontaminated the car, tried clay, ironx , tar x and even a little 1500 sand paper to try and remove and nothing seems to work. Any advice I would surely appreciate it.
    Thank you
    Angel
    Attached Thumbnails Attached Thumbnails Any tips on removing this yellowing from Tar?-image-jpg
    Super Member Tato's Avatar
    Nov 2013
    Brazil
    2,157
    Re: Any tips on removing this yellowing from Tar?
    Just to help visualizing the picture better.
    Well, tar remover will remover tar but I can't say I've seen yellowing like you are showing, from tar.
    In fact, yellowing should be corrected by polishing, but if you stated using 1500 grit and haven't removed defects you're showing, I can only expect polishing will barely do anything. Otherwise you've not sanded it properly.
    Try a better tar remover like 3M citrus tar remover, and/or to rub a compound (FG400, Meguiar's D300, M100, M105) with a Microfiber towel / applicator and see what happens.
    Let us updated,
    Kind Regards.
    ― Isaac Newton
    Super Member conman1395's Avatar
    Nov 2013
    Kansas City, KS
    1,622
    Why would you skip compound and go straight to sanding?????
    I would try a compound like M105 on a microfiber towel/applicator.
    2017 Infiniti Q60 3.0t AWD
    Super Member Dr_Pain's Avatar
    Nov 2012
    South Central, Louisiana
    2,196
    The stain is in the clear. Sanding/claying will take care of the superficial stuff, but you will need a paint cleanser/compound to get a the stain (unless you sand enough of the surface to get deep in the pores)
    https://www.facebook.com/FlawlessFinishDetailing
    Dr. Claude Tremblay, Co-owner/Senior Detailer, Certified CQuartz FINEST Installer
    Mar 2010
    Thanks for making the picture bigger.
    Sorry that I did not clearly put all the steps. But , my initial after the Decon did not work was to try FG400 with my Makita and Heavy Cut Meg wool pad. That did not do the trick. So I have tried the other steps as mentioned in my original post.
    Aug 2010
    New Jersey
    15,170
    Can you feel it in the surface?
    Mar 2010
    No it's smooth to the touch
    My though is that the tar was just laid and she ran over it while hot and could have burned the clear possibly? (just thinking out loud)
    Mar 2010
    Not that it seems like much going on, but Thank you to those who tried to give advice and help.
    Nothing was resolved with this Tar incident unfortunately. I even went to 800 grit and all it did was lighten it a little (not much) Customer was happy the black tar spots were gone from the doors and lower skirts, was still a little bummed a bout this, but over all happy the car looks great.
    Thanks again everyone.
    Super Member theamcguy's Avatar
    Dec 2007
    Fayetteville, NC
    260
    Tar stains on white are common and very difficult to remove. The best I have ever done is to dim it a bit to make it less noticeable. It does seem to go away after a long time (months) in the sun.
    Bill Strobel
    Owner Independent Towing & Repair
    Fayetteville, NC
    Do It Right or Don't Do It At All
  10. #10
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Quote Originally Posted by conman1395 View Post
    OP has already sanded w 1500
  1. Removing Burnt Titanium Tips
    By Midnite8 in forum Auto Detailing 101
    Last Post: 06-04-2019, 05:31 PM
  2. Tips on removing lint from felt seals?
    By stibuki in forum Tricks, Tips and Techniques
    Last Post: 11-16-2017, 11:08 PM
  3. How are you removing compound/polish? Any tips?
    By Scott@IncrediblyDetailed in forum Auto Detailing 101
    Last Post: 11-12-2013, 09:17 PM
  4. Tips for removing Type I Water Spots
    Last Post: 05-18-2013, 05:35 AM
  5. Tips for removing old chewing gum from leather
    By rickhill in forum Auto Detailing 101
    Last Post: 03-27-2012, 11:09 PM
