Re: Whats your best tips for interior detailing?
Originally Posted by larry33
So prior to extraction for really nasty carpets, you would go to Tornador rather than steamer? Why?
The Tornador injects the cleaning solution deep into the fabric and breaks down many of the stains before the extractor starts working. Think of it as pre treating the carpets on steroids.
A steamer works fine for this also, but the Tornador is just faster and more powerful.
Hey Mark I saw you like to use that encapsulating cleaner. I looked it up and found it was pretty pricey. I currently use Folex diluted to 4-1 with distiller water for carpet shampooing. This is very effective and price efficient, I also use a tornador to deliver this solution. I then extract or steam depending on the level of soiling.
I was wondering what the advantages of your cleaner are and how you use it?
www.JaxDetails.com
www.facebook.com/DentsAndDetails
I may be slow, but I do poor work.
Originally Posted by tw33k2514
My #1 tip for cleaning interiors would be to learn chemistry as it relates to fibers and fabrics. Know your PH scale and what each end represents.
Brown/yellow type stains: oxydizers
Red stains: reducers
Inks and dyes: solvents
Pet urine: oxydizers / acid
Upholstery: keep pH as neutral as possible.
Carpet: high pH is fine just make sure you use an acid rinse if your going to go above 12 pH on your prespray.
-note 4 powered by T-Mobile
I have tried to research stain types several times with no results Worth mentioning. Would you mind writting something that goes into détails explaining which products you use for each stain type? Solvents is very vague to me. It could mean turpentine, paint thinner, alchool, acetone, etc...
This is one area where info is badly lacking!
Thank you..that's very helpful!
Last Post: 08-20-2018, 06:01 AM
By techman41973 in forum Auto Detailing 101
Last Post: 06-19-2015, 03:53 AM
By CriticalDetails in forum Show N' Shine
Last Post: 08-02-2013, 02:13 PM
By Mike Phillips in forum Autogeek on Velocity Channel TV
Last Post: 07-05-2013, 03:21 PM
Last Post: 04-06-2012, 03:48 PM
