Results 11 to 20 of 26
    Jun 2013
    Montreal, Quebec
    3,996
    Re: 1 inch polisher pads/backing plates
    For me it's not so much a problem with budget as one having to carry around a compressor and air hoses. I am mobile and that is some serious bulk to add to what is already a ton of stuff I have to carry around.
    Super Member RaskyR1's Avatar
    Apr 2008
    Shakopee, MN
    3,733
    Sounds like you need an Evergreen compressor too!
    http://www.tri-plexstore.com/silentcompressor.aspx
    Quote Originally Posted by CieraSL View Post
    http://Raskysautodetailing.com/
  3. #13
    Junior Member Two3zz's Avatar
    Feb 2014
    48
    Quote Originally Posted by dfoxengr View Post
    Closest i can get you is the harbor freight 2" orbital sander. Backing plate is likely the same thread as griots da.
    Nope. I bought the HF and the little 2" Backing Plate is Metric. 6mm x 1.00 stud
    Ordered a few of KB's 2" foam pads and hope to test it out next week when they
    arrive. Need to get a couple of air hose fittings and a thumb wheel regulator also as I'm out of stash.
    I found where to get a replacement backing plate should the need arise, and ordered a 3" inch plate with the metric stud in hopes of using it with some of my existing pads or I will hit up Kevin again.
    PM me
  4. #14
    Dec 2013
    raleigh NC
    139
    Makes sense. I wonder about cutting down 3" plates on a lathe and pads with a razor...
  5. #15
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Quote Originally Posted by Calendyr View Post
    I don't think a portable compressor is up to the task of powering the Rupes TA50
    Air requirements:
    Pressure:
    bar 6 / 88 PSI approximate
    Consumption:
    330 liters / 87GPM / 11.7 CFM
  6. #16
    Quote Originally Posted by RaskyR1 View Post
    The TA50 is great for pillars and tight areas.
    Looks like it will not only be good for tight areas but for something I teach called edging....
    Autogeek carries this now tool....
    Rupes TA50 Mini Sander - First look...
    On Autogeek.net
    Rupes TA50 Mini Random Orbital Sander
    Sanding Discs
    Trizact 6 inch #5000 Grit Foam Discs
    Trizact 6 inch #3000 Grit Foam Discs
    Meguiars Unigrit Foam 3000 6 Inch Finishing Discs
    Meguiars Unigrit Foam 1500 6 inch Finishing Discs
  7. #17
    Super Member goldendodo19's Avatar
    Jul 2013
    638
    That polisher looks like a toy lol
  8. #18
    Newbie Member Mk1 AG's Avatar
    Aug 2013
    NM
    [QUOTE=goldendodo19;1083437]That polisher looks like a toy lol
    It is but I'll have to stick with my 2" HF unit for now.
  9. #19
    Junior Member Anomander's Avatar
    Jul 2013
    Albuquerque
    64
    Richard Lin used one that looked to be smaller than 2 inches
    Rupes LD30 1" Orbital Polisher - YouTube
  10. #20
    Jun 2013
    Montreal, Quebec
    3,996
    Using that backing plate on a drill would probably be the best solution for me until I can get an air compressor.
  1. 5 inch Backing Plates on Meguiar's, Griot's and Porter Cable DA Polishers
    Last Post: 03-01-2014, 07:40 AM
  2. Replies: 19
    Last Post: 02-16-2014, 11:49 AM
  3. Is the Rupes 15 and 21 the same polisher just different backing plates?
    Last Post: 06-14-2013, 01:12 AM
  4. D/A backing plates (5 inch)
    By I Shine in forum Auto Detailing 101
    Last Post: 08-16-2012, 10:16 AM
  5. 5 Inch Backing Plates for DA Polishers - Pictures and Links
    By Mike Phillips in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-16-2010, 03:35 PM
