Results 11 to 20 of 23
    Super Member Crispy's Avatar
    Jun 2013
    779
    Re: Rubber on door sill
    On my car these moldings are not permanently attached and you can simply pull them off and clean them a small section at a time. They have a stiff metal inbeded in the portion that attaches to the car and the top part is very plyable so easy to clean and dress.
    Oct 2012
    456
    Use Meguiars rubber and vinyl cleaner
  3. #13
    Aug 2014
    1,445
    My supplies when I clean weather stripping is:
    1: A bucket of hot water mixed w/ ONR and a few MF towels.
    2: A couple of brushes
    3: A decent APC
    I wipe the rubber with a wet mf towel, then use the apc for any really dirty spots. All of this is followed by a dry towel. The brushes come in handy to reach anywhere your finger(s) and a towel won't reach.
    The bucket of hot water, to me, is the most valuable peice because the rags can be rinsed in the bucket, and I find cleaning weather stripping is faster if hit quickly with a wet rag first,instead of spraying the whole length of rubber with apc follwed by scrubbing with a brush. my 2 cents...
    By the way, Mother's Foaminh Wheeel and Tire Cleaner works great on weatherstripping. Just follow it with a dressing.
    "I've seen a good quality car wash look better than some guys complete detail jobs."
    Mike Phillips 10/21/09
  4. #14
    In time out
    Nov 2012
    South of Atlanta
    3,937
    Quote Originally Posted by Kevin Cullen View Post
    If I am going to clean the interior anyway and don't mind a little water inside I turn my pressure washer pressure down way low and use that to clean the area or hold my water hose spray nozzle real close and gently squeeze the trigger just abit to get a little water to come out.
    If it is just a touch up I will use rinseless wash in a trigger bottle, wipedown and then reapply protection.
    THIS
    Maybe a spray with diluted APC/APC+ and agitation with a boars hair brush then hit it with the pressure washer. Wipe down after a spray with D114.
    Finally, (after finishing your interior job) dress with your preferred VRP.
  5. #15
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    +4 on 1Z Gummipfledge. I also like to keep them clean often which means reapp of Gummi.
    Clean and moistly treated has kept my 07 seals like new! And cleaning means cleaning off the inside of the door jamb where they press when closed.
  6. #16
    Newbie Member RichElliott's Avatar
    Apr 2015
    Beaverton, Oregon
    Quote Originally Posted by Ncs0816 View Post
    It seems like a few people are recommending this. I'm ordering it right now. The name shows as : M40 Meguiar's Vinyl & Rubber Cleaner & Conditioner. I'll put some feedback on here after I tried it out.
    Rich Elliott
    2014 Oxford White Ford Focus ST
    LocalCred
  7. #17
    Super Member builthatch's Avatar
    May 2008
    east coast
    2,352
    if really dirty:
    vac with my various small tips
    ONR mixed in a spray bottle
    brush/cheap MF
    Power Clean at varying strength if necessary
    wipe dry
    if it's aging, i'll use Optimum Protectant on it
    otherwise, for upkeep, i vac and use Opti-Clean and an MF.
  8. #18
    Super Member tenblade2001's Avatar
    Sep 2014
    808
    just received 1z Gummi Pflege...got it with amazon points.
  9. #19
    Aug 2014
    445
    Anyone used BF tire and trim sealant on door/trunk seals? Im still waiting for my BF T&T to arrive but was considering getting the gummi pfledge too.
  10. #20
    In time out
    Nov 2012
    South of Atlanta
    3,937
    Quote Originally Posted by d33p View Post
    Well yes, yes indeed.
    That, along with UTTG+ I've used quite a bit.
    Neither smell very good at all, REALLY have a solvent/industrial smell, but they work great. You can take a foam applicator (maybe an old worn buffing pad cut into pie shaped pieces), a foam paint brush, even a bristle brush and get into complicated places (like the cowl area).
  1. Door jam /sill ?
    By luckydawg in forum Auto Detailing 101
    Last Post: 10-20-2020, 06:34 PM
  2. door sill scratches on 2016 4runner
    By Toolhead in forum Auto Detailing 101
    Last Post: 05-16-2017, 05:06 PM
  3. Cant Remove these marks from door sill area
    By Rhudeboye in forum Ask your detailing questions!
    Last Post: 07-31-2016, 07:24 PM
  4. Light scrathes in aluminum door sill
    By XJL in forum Ask your detailing questions!
    Last Post: 01-08-2015, 09:56 AM
  5. removing scuff marks on door sill plastic
    Last Post: 06-30-2011, 08:36 AM
