Results 1 to 10 of 10
    Regular Member kdubski's Avatar
    Dec 2010
    Central, CT
    195
    2007 Mercedes benz ML350
    AG Guru's I need some noobie advice! I detailed a 2007 ML350 this past weekend and I had a hard time with the wheels. The rotors/rotor guard is so large that I cannot fit my daytona speed brush under it. This goes as well for the Caliper because it's so large I probably can barely slide my finger between it and the wheel.
    I have a second ML350 lined up for this weekend and it has the same wheels as the last one I did. Any advice on how to agitiate the brake dust in such a narrow wheel? Taking the wheels off is not an option at this clients house. Also, this is just a wash and wax service but normally i leave them spotless, not 2-3" into the wheel. Thanks guy!
    It's never too late to learn a little.
    Super Member Bill1234's Avatar
    Apr 2012
    New York, NY
    2,647
    Re: 2007 Mercedes benz ML350
    might want to buy some iron x, would make cleaning them faster
    Bill 1234
    2004 audi a6 quattro (traded).
    2015 Ford Escape 2.0l ecoboost 4WD
    Dec 2010
    Central, CT
    195
    Don't have Ironx X, nor do I think I can get it by the next detail. Any other over the counter chemicals or tools I can get a hold of locally to help?
    Apr 2012
    New York, NY
    2,647
    try meguiars hot rims all wheel, works really good on soiled rims
    Bill 1234
    Dec 2010
    Central, CT
    195
    Is it more potent then Megs WB? Thats what I'm armed with at the moment and even after 3 applications there was a TON of spots on the inner wheel barrel. Sorry to be a hassle Bill but appreciate the advice!
    Super Member EddieF's Avatar
    Jul 2012
    Lake Hopatcong NJ
    327
    Try some zep citrus degreaser, you can get it from home depot, or lowes.
    Apr 2012
    New York, NY
    2,647
    meguiars wheel brightener is very acidic, Better for the german wheels are they are usually soiled in brake dust. I would try a bit of meguiars hot rims and try and scrub the acid stains out of the wheel
    Bill 1234
    Jun 2012
    671
    My ML350 (2012 model) is not too bad for brake dust and I have used several products that are spray on/rinse off and require only minor brushing or agitation. CG Diabalo is one of the best but the two you can find locally are Mothers Tire and Wheel Foaming Cleaner and Griot's Wheel Cleaner. They both work well on my ML350 and the Mother's can be found almost everywhere; the Griot can usually be found at Advance Auto. I can also recommend Meguiar's D143 for Mercedes brake dust, which I believe may be virtually the same product as Hot Rims All Wheel Cleaner. If so, Hot Rims can be found locally as well.
    Dec 2010
    Central, CT
    195
    I appreciate the input guys! I already use megs WB and have been for quite a few seasons now. Aside from this specific 2007 ML350 wheel, which remains dirty after many applications, it has worked wonders on other vehicles. I just detailed a SECOND ML350, same year, with the same results. The face of the wheel cleans off beautifully, but the inside of the wheel remains dirty. Best I can describe it is speckled brown caked brake dust/rust spots. It just looks disgusting. Shortspark, I have detailed newer ML350 with flawless results, something with the wheel/brake assembly must be corroding the wheels quickly.
    P.S. Simple green, Megs APC, and Megs WB have had little to no success on the INSIDE of the 2007 ML350 wheel. If anyone has any other advice please let me know!!
  10. #10
    Junior Member Millennium's Avatar
    Jan 2010
    Atlanta, GA
    38
    Seems as if that vehicle wasn't being properly hand washed prior to you. It might take multiple washes to bring to "perfection". I've had those that no matter what we use it gets cleaner but not perfect. I use a acidic cleaner to get those tough stains out. Try not to use it on the face of the wheel. You might want to use a longer and stronger wheel brush.
    Millennium Auto Care
    http://detailing-solutions.myshopify.com
    Follow me on instagram @millenniumguy
  1. 2013 Mercedes Benz ML350 that went to the dogs
    By Sean M at ShowShine in forum Show N' Shine
    Last Post: 03-31-2017, 08:37 AM
  2. Mercedes-Benz ML350 Detailed!
    By Bryan C. in forum Show N' Shine
    Last Post: 05-27-2014, 12:53 PM
  3. 2007 Mercedes Benz S550
    By BlackRam in forum Show N' Shine
    Last Post: 04-26-2014, 08:13 PM
  4. Mercedes-Benz E280 (2007 Black) - Opti-Coat
    By Disciple in forum Show N' Shine
    Last Post: 08-30-2013, 05:09 PM
  5. Replies: 27
    Last Post: 02-10-2011, 11:32 PM
