Results 11 to 20 of 23
    Newbie Member 70_Nova's Avatar
    Feb 2012
    Re: Tire Dressing Applicator Suggestions
    Well thanks for the tips, I will definitely have to give it a try.
    Aug 2012
    58
    Great tip, what product works well with a brush?
  3. #13
    Jun 2012
    671
    As I said in my previous post, all dressings that require application (as opposed to spray and walk away foams) work well with a paint brush. I like Meguiars Hot Shine and also their Endurance. With Hot Shine I spray it on the tire and work it in with the paint brush - you do not need much as the brush spreads it thin. The Endurance is a gel type liquid (at least it use to be) although I believe it now comes in both aerosol and a mister spray. With the gel I simply put several drops on the brush which is why I recommend a tightly knit brush in order to hold the gel in the bristles. I also use Protectant 303 on tires now and then and a brush is critical to spread out this product because it just sits where you spray it and does not dry uniformly like the dedicated tire dressings. Lately I've been trying Duragloss 265 because I can use it on everything, not just tires. I have found that I don't need to spread it out nearly as much as the other products. Just a light movement of the brush into the tire markings, lettering and design features is all you need if you use 265.
    You may have to go through two or three different brushes until you find one that best fits your hand and works well with the specific product you choose. Don't worry about getting a pro painter's brush as the cheapos under five bucks work just as well (as long as the bristles are tightly woven) - remember, you are simply spreading tire dressing, not touching up a Rembrandt masterpiece here.
  4. #14
    Super Member richy's Avatar
    Mar 2007
    Windsor, Ontario
    5,158
    I have had great success using a small paint gun with my air compressor: very uniform look, quicker application to boot. Never going back to the old way again!!
  5. #15
    Regular Member rdf's Avatar
    Mar 2006
    115
    Paintbrush. What a genius idea. Also a Homer-type "d'oh!".
    Thanks for the suggestion!
  6. #16
    Regular Member Infinitiman's Avatar
    Mar 2012
    Knoxville Tn
    157
    Not to thread jack here, but, I've seen them used at the Infiniti dealership and I noticed Swissvax sells them too. To those that do use them, is there an issue with using to much dressing, that you have to wipe off??
    Sent from my iPad using Tapatalk HD
  7. #17
    Super Member DaHen's Avatar
    Sep 2010
    Eastern MA
    1,215
    Quote Originally Posted by Infinitiman View Post
    Seems like I alway over do it when applying any tire dressing. (Don't t want to miss a spot.) End up giving the tires a quick wipe down.
    Smoke Metallic '06 Altima
  8. #18
    Super Member JAF06SE's Avatar
    Jul 2012
    361
    I always used a cotton wax applicator when I used to use one for tires. The dressing I'm addicted to now has a really fine mist that is easy to control and goes a long way.
  9. #19
    Jun 2012
    980
    not to go over to the dark side, but adam's makes a great tire dressing applicator - best I've tried.
  10. #20
    Super Member RMM's Avatar
    Apr 2012
    Lisboa, Portugal
    1,432
    Quote Originally Posted by Shortspark View Post
    A paint brush with fine, thin bristles that are tightly wound with a high concentration of bristles (thick but short with softest bristles you can find). Clean off with a rag after each use and store in a baggie. Perfect control especially around rims, cheap to purchase almost anywhere, don't have to wear rubber gloves on your hand, works with every product, won't waste dressing because you can spread it very thin if you wish just like you would paint which helps control the amount of gloss you want - bonus is a brush lasts a long, long time. The secret is finding a brush with short, fine bristles that are fairly tightly compacted together. Find the right brush and you'll never go back to a foam applicator.
    That's what I usually use, too: in fact I have been using it since I was a little kid (when I applied a alcohol + glycerin concoction bought by my father...I didn't know better!).
    The only thing I do prior to using it is put some masking tape on the metal part that holds the bristles (to prevent any accident).
  1. Best tire dressing applicator
    By Mad Wax in forum Auto Detailing 101
    Last Post: 09-04-2015, 09:21 PM
  2. Tire Dressing for use in a tank Applicator
    By Dave Medvic in forum Auto Detailing 101
    Last Post: 08-11-2013, 06:09 PM
  3. Carrand Tire Dressing Applicator
    By Shakabruddah808 in forum Product Reviews
    Last Post: 04-15-2013, 08:28 AM
  4. What is your favorite tire dressing applicator?
    By wanabe detailer in forum Auto Detailing 101
    Last Post: 03-10-2013, 06:02 PM
  5. Finally, A Tire Dressing Applicator I Like
    By HighFive in forum Product Reviews
    Last Post: 03-28-2012, 02:51 PM
