What do you mean by Ruined? Do you mean their flat now?
My sentiments precisely. What products used? Tearing usually operator error. Separation usually heat transfer issue. I too am waiting on the optimum pads since I will be using the optimum products in concert. The perceived flatness issue is what initially kept me from the mf cut pads . Heat is a mortal enemy of mf imo. Happy trails...
I would assume the MF portion has come off of the foam backing. Like it was mentioned if it tore it's probably due to catching the pad on somethig, but if it delaminated, it's due to heat build up, or working with a pad that is still wet on a DA machine.
