Its usually a clear vinyl sticker that can be taken off like any other sticker that you've faced in your lifetime. Afterward you can you use a product like Goof Off or Goo Gone to take off the adhesive residue that's left behind.
i just completly removed vinyl graphics on sides of two vehicles, im talking full length. i did start out with a little heat but then noticed it left more adhesive residue on the paint, than not heating it up fully. so i just heated the edge up to where i could catch it with my fingernail and pulled it off. yes it did break at times, but then i just started over again. after graphics were removed of course there was a lot of wax build up around where the graphic was. i then used plasti-kote wax and grease remover to rid of all the leftover adhesive that did not come off with the graphics. it took some rubbing but i got off all the adhesive. i could not even tell that the graphics were there and they were on for 2 plus years. i did proceed to use an aio and then topped with collinite.
