Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Junior Member Jsuro's Avatar
    Mar 2011
    78
    About Tire Dressing and Applicators
    Hi all,
    New here but I thought I share a tip, not really an article though.
    I've always thought that properly cleaned and dressed tires are as important to the look of a car as a dazzling paint job. Over the years new products and applicators have come to the market and I have tried my share of them. Some dressings don't last at all while others make the tires brown after a while. Some are really glossy some are not.
    I prefer a long lasting dressing that does not turn the tires brown. I don't like a high gloss but I like the tires to look shinny if that makes sense, like the rest of the car. I finally settled on Meguiar's High Gloss Hot Shine tire dressing.
    High Gloss? Yes, if you spray it on it is very glossy and it also gets all over the wheels. Even if you wipe the wheels, in a car with high carbon brakes like my X5 the wheels go black quickly because the stuff just wants to turn things black and it lingers on the wheels even after wiping. But, it lasts forever and it never turns brown. As I said, I don't like high gloss, but the stuff lasts forever if you clean your tires well on the first application. Tires are tough, so for my initial cleaning I use a VERY stiff brush on them. This is the brush:
    I think its used for concrete. Stiffest brush I could find!
    But what about the high gloss? I don't like that! Well, if instead of spraying it on you wipe it on then it's not high gloss at all, it's perfect.
    We now get into the applicators. Spraying - too much gloss and a mess on the wheels. Commercial foam applicators work perfectly but are a bit expensive for the life of the applicator, and they all get messy. Getting close to the rims without getting black stuff on them is hard to do. Disposable rags don't work because they soak up too much product and don't lay it back out, making the tires not shinny.
    What to do? I thought about this for along time. The foam on the commercial applicators is perfect, but kind of costly considering the mess an the lack of fine edges to get close to the rims.
    Well, it came to me one morning while walking around the local home improvement store. And here it is:
    I call them Lollipops . They are $.85 cent disposable foam brushes. They come in sizes from two to five inches for all the different tire widths and last for about 5 cars when stored in plastic baggies. I use the 3-inch size. They have a sharp edge so I can get all the way to the edge of the rims without getting product on them. The foam is designed to hold a lot of product but to also put it all out so five really short squirts from the bottle will do one tire and so a bottle of product now lasts forever.
    And, as I mentioned above, I am not spraying the product onto the tires anymore so I get the perfect shine, not a high gloss and no mess on the wheels.
    This is how my tires look after about 10-hours after application:
    Not a high gloss but very shinny, and the stuff will last even after washings. As an aside, I use Klasse AIO and Klasse High Gloss Sealant on the wheels - really keeps the dust off of them
    Hope this helps .
    Best,
    Jose
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    Re: About Tire Dressing and Applicators
    I like foam wax applicators, cheap and hold enough dessing. To get the best out of any dressing tires do need to be cleaned often and old protectant removed.
    Scott
    Super Member JonMiles's Avatar
    Jan 2010
    Sarasota, Fl
    921
    How does the Glenmorangie come into play?
    Jon Miles
    Mar 2011
    78
    Quote Originally Posted by JonMiles View Post
    LOL! No branding so you recognized it. I do sip single malt after hours on weekends at home. Just happened to be on the work bench that Saturday after a long detail day. Not used for tire dressing!!! .
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    It's used to clean his tire applicator.
    Super Member Old Tiger's Avatar
    Oct 2009
    Up State SC
    4,468
    Really good post Jose. Welcome aboard!
    Oct 2009
    Up State SC
    4,468
    Well Ron, it tastes better than IPA!
    Super Member GaDetailDoc's Avatar
    Dec 2010
    277
    I use this applicator to apply lacquer to wood after it has been stained. Will give this a try. Got one sitting around in the garage.
    Super Member Shane731's Avatar
    Dec 2009
    Madison, AL
    3,498
    What kind of tires are on your Beemer? I can see the Michelin part, but can't make out what type of tires they are.
    Shane
  10. #10
    Mar 2011
    78
    Quote Originally Posted by CieraSL View Post
    They are the factory tires - Latitude Tour HP Runflats 255/55-18. I thought I wouldn't like the runflats but I do now. They're a bit stiffer ride wise but the car corners like on rails. And a lot more storage space where the spare used to live .
    Best,
    Jose
  1. Tire dressing applicators- storage and cleaning
    By davidc11291 in forum Auto Detailing 101
    Last Post: 05-26-2012, 12:40 AM
  2. New! Carrand Brush & Shine Tire Dressing Applicators
    Last Post: 05-07-2012, 06:22 PM
  3. Tire Dressing Applicators From Harbor Freight
    By tenorplayer23 in forum Auto Detailing 101
    Last Post: 11-06-2009, 01:30 AM
  4. Cobra Flex Foam Tire Dressing Applicators
    By dengood1 in forum New Car Care Products
    Last Post: 05-27-2007, 09:37 AM
  5. Flex Foam Tire Dressing Applicators
    Last Post: 04-14-2007, 08:08 AM
