Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. #21
    Super Member HighEndDetail's Avatar
    Apr 2006
    Cobb county, GA
    1,881
    Re: Dakota Odor Bomb Trick
    Try this
    Meguiars Car Odor Eliminator is a quick spray solution to interior car odors. Meguiars Car Odor Eliminator does not mask odors - it eliminates them!
    Or Biokleen product called bac out. That should work, you have to kill the enzymes from the milk. That is what is causing the smell
    Ed
    Moderator/Consultant for Autogeek.net
    To achieve excellence, excellence cannot be rushed. Technique is just as important as the product used.
    While my approach takes more time, the results are far superior.
  2. #22
    Mar 2011
    PA
    5,794
    this might be the ticket.....
    Auto Vaccine & Auto Shocker Odor Removal
    2018 Colorado ZR2
  3. #23
    Super Member BobbyG's Avatar
    Dec 2009
    Southeast, MA
    13,211
    Quote Originally Posted by rakkvet View Post
    I was just going to mention using an enzyme bacteria digester. Your spill is organinic. The trick is to mix it and let it fully saturate the spill I think you let it sit about 12-24 hours and then simply extract.
    BINGO!!
    The odor presents itself once bacteria begins to form and grow. Until the bacteria is destroyed or digested it will continue to produce this lovely odor.
    Eliminating this odor at the biological or organic level is the only surefire way I'm aware of short of replacing the entire interior.
    Pet stores carry these products and for good reason....they work.
    Generally, these liquids are applied liberally to the affected area and a little beyond. Fully saturate this area and leave wet for 24 to 48 hours.
  4. #24
    Super Member IID's Avatar
    Sep 2010
    Northwoods
    2,195
    [QUOTE=RoPaJa;433246]Just wondering what if anything got rid of the milk smell?[
    The So2Pure did the trick.It worked well.
    Team Flex PE14-2 150(Serial#0005)/3401/3403/XFE 7-15
  5. #25
    Super Member richy's Avatar
    Mar 2007
    Windsor, Ontario
    5,158
    [quote=ImpressiveImageDetailing;433354]
    Quote Originally Posted by RoPaJa View Post
    I'm glad to hear the SoPure worked for you. I knew it would solve your problem.
  6. #26
    Sep 2010
    Northwoods
    2,195
    [quote=richy;433707]
    Quote Originally Posted by ImpressiveImageDetailing View Post
    Absolutely did Richy,
  7. #27
    Super Member pixelmonkey's Avatar
    Sep 2010
    Oklahoma
    533
    box with holes from a recent autogeek delivery.
    sat it atop a rubbermaid lid from a gray tub.
    2 hours after pushing the button, i removed the lid with the remaining pink goo that was contained in the box.
    smokers odor seems to be gone. really cant tell yet over the baby power smell the Dakota Odor Bomb expels.
    I'll check the car after 1 week of the wife driving around. I'm thinking the baby powder smell should be gone, and if there is any smoke smell left I'll be able to identify it.
    richy, have a link to "SoPure"?
    thanks
    chris<pixelmonkey>
  8. #28
    Super Member DLB's Avatar
    Jul 2009
    Ringgold, GA
    1,211
    Quote Originally Posted by pixelmonkey View Post
    thanks
    chris<pixelmonkey>
    Autogeek sells it now.
    CarPro So2Pure Air Purifying Coating 120 ml. FREE BONUS
    They just became a distributor, therefore, no linking was allowed (hence richy PM'ing the OP).
    DLB
  9. #29
    Sep 2010
    Oklahoma
    533
    Quote Originally Posted by DLB View Post
    DLB
    excellent!
    if the smoke smell is present after a week, i'll add this to the next order.
    thank you!
    chris<pixelmonkey>
  10. #30
    Mar 2007
    Windsor, Ontario
    5,158
    DLB
    Thanks Dalton.
    If you use this product, read the instructions. It needs exposure to light to activate it.
  1. Dakota odor bomb=sticky headliner???
    By hoyt66 in forum Auto Detailing 101
    Last Post: 09-07-2015, 06:10 PM
  2. DP Odor Eliminator bomb "trick"
    Last Post: 02-02-2014, 10:03 AM
  3. Dakota Odor Bomb with leather interior?
    By andaheart in forum Auto Detailing 101
    Last Post: 12-05-2013, 09:51 AM
  4. The Dakota Odor Bomb
    By shanew in forum Auto Detailing 101
    Last Post: 01-24-2012, 09:56 AM
  5. Dakota Odor Bomb
    By Perfessor in forum Auto Detailing 101
    Last Post: 08-01-2010, 06:45 AM
