Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Jun 2009
    Stuart, Florida
    38,241
    Best Practice - Avoid buffing on top of body lines and edges
    Buff up to body lines and edges but try not to buff directly on top of body lines and edges
    A good best practice whenever you're machine cleaning is to buff up to hard body lines but don't buff on top of hard body lines. There are two reasons for this,
    1. Paint tends to flow off high points a little after it's sprayed but before it's set-up, so paint will tend to be thinner on edges and body lines.
    2. There will be increased pressure from your pad onto the paint because the body line or raised edge will be higher than the rest of the surrounding paint.
    This is what can happen, if you look carefully at the hard body line on the hood of this VW you can see where someone has remove too much paint and exposed the primer under color coat. This is an older VW and has what appears to be a single stage finish but the principal behind avoiding buffing directly on top of an edge or hard body line still applies.
    This is a little out of focus, sorry I was using my iphone...
    As Benjamin Franklin once said, an ounce of prevention is worth a pound of cure.
    A good best practice is to avoid buffing on top of hard body lines and edges and instead just buff up to them. You can also tape them off using thin painter's tape so in case you get your buffing pad close to the raised body line or edges you have a measure of extra protection.
    This is where either slowing down and focusing on the task at hand comes into play or using smaller pads when working on thin panels.
    Here at Autogeek we have a great selection of smaller buffing pads and backing plates as well as the Griot's Garage Professional Random Orbital 3 Inch Polisher for working thin panels.
    Lake Country Beveled Edge 3.5 Inch Pad Pack
    Griot's Garage 3 Inch Orange Polishing Foam Pad
    Griot's Garage 3 Inch Mini Red Wax Pad
    2-3/4 inch Hook & Loop Rotary Backing Plate
    D.A Adapter 5/8" X 11
    Lake Country 4 Inch Low Profile Foam Pads
    CCS 4 Inch Spot Buffs Foam Pads & Accessories
    3.5" Dual Action Flexible Backing Plate
    Rotary 3 ¾ inch Backing Plate
    Host - Competition Ready on Velocity Channel
    IDA Board Member
    CD-SV, RT
    Competition Ready Facebook Page
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
    Junior Member eddie6th's Avatar
    Aug 2009
    Re: Best Practice - Avoid buffing on top of body lines and edges
    Painters tape!...Where would I be without it.
    'Pearly Gates'
    Senior Member MisterShark's Avatar
    Jul 2009
    254
    Great tips for someone like me whose on the verge of buying a PC and would like to be forearmed with a bit of advance knowledge.
    Keep em comin Mike!
    James
    Apr 2008
    196
    Nice write up. I have used those 4inch spot buffs many times, life savers for tight spots.
    Senior Member Gary Sword's Avatar
    Nov 2006
    Southwest Florida
    4,168
    Good Advice! Sometimes I even tape an edge that's hard not to hit.
    Senior Member DLB's Avatar
    Jul 2009
    Ringgold, GA
    1,211
    Been wanting to pick up some of the 4" pads and backing plate - just got to get my funds built back up.
    DLB
    Aug 2009
    Maybe I'm a bit late to the party, but how do you guys buff body lines and odd panel contours? I tried polishing a friends Nissan Hardbody pickup with my PC, but it has a sunken channel right through the waistline that I couldn't get even w/ a 4" pad. Any tips for dealing with this and other areas where a PC can't reach?
    Jul 2009
    Ringgold, GA
    1,211
    Quote Originally Posted by Omar the Terror View Post
    I usually always go back around a vehicle with my product and an applicator of choice and hit the spots by hand that I couldn't get by machine.
    There's just some things that the machine can't do for you.
    DLB
    Aug 2009
    So you can make those hard-to-reach spots match the machine-polished portions of the car, or does it sometimes leave an obvious difference between the machine and hand-polished areas? Also, what applicator do you recommend for this? I have some LC CCS hand pads on the way but if there's something better, I'd love to try it out. Thanks!
  10. #10
    Jun 2009
    Stuart, Florida
    38,241
    Quote Originally Posted by Dalton Blevins View Post
    DLB
    That's a good point and that's why it's important to know how to properly apply a hand-applied compound or paint cleaner.
    IDA Board Member
    CD-SV, RT
    Twitter
    Instagram
  1. Body lines
    By Dman81 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 08-07-2015, 10:32 PM
  2. Polishing and Body Lines
    By Corey06 in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-29-2015, 09:45 PM
  3. Taping raised lines/edges?
    Last Post: 03-09-2014, 08:13 AM
  4. Buffing around handles and contours and body lines
    By silvermesa in forum Auto Detailing 101
    Last Post: 06-06-2012, 09:48 PM
  5. How to avoid dry buffing
    By sqeekykleen in forum Auto Detailing 101
    Last Post: 09-14-2008, 03:57 PM
» January 2018
28 29 30 31 123
