Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
  1. #1
    Super Member aztec1987's Avatar
    Join Date
    Mar 2013
    Posts
    668
    Post Thanks / Like
    How to get better foaming on cannon?
    I've been recently searching around how to get better suds from my foam cannon; I've been reading that if you have a low pressure electric pressure washer a 1.15 orificer will be better and a 1.25mm is for higher PSI pressure washers. However the one I currently have has a 1.15mm and wash with a 1700 psi with 1.7 gpm flow. When testing its been watery; can anyone recommend some tips and tricks? Also what orificer to use psi/gpm; I've been using CG Snowfoam with 3 oz to 10 oz water dilution ratio. Appreciate the 2 cents!
    "I don't consider myself to be the best.. and I don't like compliments.. they distract me." - Jimi Hendrix
  2. #2
    Super Member
    Join Date
    May 2013
    Location
    TN
    Posts
    1,768
    Post Thanks / Like
    Re: How to get better foaming on cannon?
    Another option is something like Blackfire Foam Booster. I’ve read quite a few reviews where people used 1/2 oz of the foam booster and reduced their primary soap down to 2 oz while still providing much better foam.
    BLACKFIRE Foam Booster, foaming booster shampoo
  3. #3
    Super Member briarpatch's Avatar
    Join Date
    Sep 2015
    Posts
    2,173
    Post Thanks / Like
    Quote Originally Posted by aztec1987 View Post
    So....using CG Snow foam (guessing Honeydew?).....an d 3oz of soap to 10oz of water...with an electric pressure washer...and you switched out the orifice to the 1.1mm....correct? Are you using (at least) warm water in the cannon? First thing you need to understand is that the specs on your p/w are probably way overstated. Lots of things can affect the consistency of the foam.....water temperature, air temperature, water hardness and/or quality.
    With the combo you mentioned, you should get foam that is decent....not shaving cream thick foam, but better than watery. I do not think I'd go for more soap....maybe a different one. With a similar setup, I've gotten good foam with P&S Pearl shampoo, MTM Perfoamance, and Jay Lenos Vehicle Wash. All three are pretty economical and would be worth giving a try.
  4. #4
    Super Member 57Rambler's Avatar
    Join Date
    May 2019
    Location
    Columbus, OH
    Posts
    1,026
    Post Thanks / Like
    Question : Is the amount of foam generated really indicative of cleaning power, lubricity, etc. ? I ask because we had a similar discussion about the amount of suds generated by different car wash products, whether it really made any difference as products are formulated differently.
  5. #5
    Super Member psnt1ol's Avatar
    Join Date
    Aug 2012
    Location
    San Francisco
    Posts
    892
    Post Thanks / Like
    you might want to try a lower dilution ratio (4oz to 10 oz warm water) for the soap solution with the knob turn to the highest soap to water setting.
    A higher quality trigger gun (MTM SG28) will also help in increasing suds. Not all foam cannons are equal. I have several foam cannon ranging from cheap amazon specials to the higher price units. I have a better experience with the MTM products in general.
    Another factor is the quality of your water source. I have hard water in my area and I found a big gain in subs by adding a water deionizer plus it also address the water spotting issue at the same time.
  6. #6
    Super Member Coatingsarecrack's Avatar
    Join Date
    Dec 2018
    Posts
    7,193
    Post Thanks / Like
    What kind of foam cannon. I tried several different ones and only one was decent. Bought the bullet and got the MTM PF22. Much better with my 2100psi 1.2 gsm ryobi.
    Make sure you have mixture turned all the way up and you stated 1.5 mm should be a 1.1. Check those and if all is good buy a new cannon.
    If it’s one of those $15-20 jobs in amazon that is your problem
  7. #7
    Newbie Member
    Join Date
    Jul 2019
    Posts
    3
    Post Thanks / Like
    Optimal Сasual Dating - Verified Maidens
    Experience carefree connections with the top-rated site for casual dating adventures. Live Women Finest casual Dating
Similar Threads
  1. Review: Griots Garage Foaming Surface wash and Foaming Poly Gloss
    By Justin at Final Inspection in forum Product Reviews
    Last Post: 04-01-2020, 09:14 PM
  2. Wolfgang foam cannon not foaming
    By 01GreyStangGT in forum Auto Detailing Tools and Accessories
    Last Post: 08-27-2018, 10:19 AM
  3. Does foaming the car REALLY help or not?
    By evo77 in forum Auto Detailing 101
    Last Post: 05-07-2018, 02:15 PM
  4. Foam Cannon HP Foaming Lance for your Pressure Washer
    By Dwayne in forum New Car Care Products
    Last Post: 08-30-2016, 09:30 PM
  5. AIO Foaming
    By OCD Detailing in forum Auto Detailing 101
    Last Post: 07-18-2015, 02:41 AM
Members who have read this thread: 16
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
