Dislikes: 0
first time using porter cable 7424xp and m205
hey guys
so its going to be my first time using porter cable 7424xp and also using m205, I will be putting on cquartz for the first time so I just want to make sure everything right. I have my 5 inch backing plate and lc white pad, whats the best way to apply m205 to the car, what speeds and passes? Been trying to youtube a few videos any good guides or advice please will be much appreciated
thanks guys
Re: first time using porter cable 7424xp and m205
Test spot, a good estimate is speed 5, 6-8 section passes. Do you have everything to prep the surface and ensure it's bare before applying CQuartz?
yes I do have everything for prep claybar, iron-x etc
Super Member
I use 4 pea size drops to the pad, I start on speed 2 to spread the polish over a 2x2 area then kick it up to speed 5 and make 4 passes keeping my arm speed slow and moderate pressure.
Very easy to wipe off, I love 205.
Make sure you're happy with the test spot before moving on, you don't want to have to do the entire car again later if not satisfied with the results.
What are you using to remove M205 oils to leave bare paint for your coating?
I like to rewash with cg cwg before Applying lsp.
Sent from my SAMSUNG-SGH-I777 using AG Online
Thanks for that
so after I polish the car should I wash the car again or use a MF to buff it off?
I will be using carpro Eraser
Similar Threads
By carlg in forum Auto Detailing 101
Last Post: 08-22-2018, 11:00 AM
By RLucky82 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 01-23-2013, 05:42 PM
By kms254 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 01-22-2012, 07:09 AM
By grandprix2plus2 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 12-29-2011, 11:54 PM
By Meghan in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 06-25-2009, 06:46 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
