Dislikes: 0
Regular Member
m105 mf cutting pad or lake county
should i use a mf cutting pad or lake county with m105 or m205.thanks
Super Member
Re: m105 mf cutting pad or lake county
Usually a Lake County pad works best, the MF cutting pad might work, but it's iffy. I would just stick with the Lake County pad.
Depends on how bad your paint is? M105 works amazing with the MF pads. A foam cutting pad will not cut nearly as much as a MF pad. Use M205 with a foam pad.
Similar Threads
By Bill1234 in forum Auto Detailing 101
Last Post: 10-17-2014, 02:55 AM
By dcgocd in forum Wool & Foam Buffing Pads
Last Post: 05-01-2013, 07:14 AM
By dcgocd in forum Auto Detailing 101
Last Post: 04-30-2013, 06:26 AM
By Lstotland in forum Introduce Yourself
Last Post: 11-12-2011, 09:27 PM
By m4bama in forum Auto Detailing 101
Last Post: 06-16-2010, 01:33 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
