Dislikes: 0
Megs Hyper Dressing/fabric cleaning
Has anybody used this product for the interior of the car?
If so what is the dilute ratio that works well for the interior?
Also looking for a good carpet shampoo, any suggestions?
I have fabric around the arm rests that need cleaning.
What is the best way of cleaning these areas?
Have a good weekend everyone!
Super Member
Re: Megs Hyper Dressing/fabric cleaning
I have not used HD for interiors,but I use it 4:1 for wheel wells and engine compartments and sometimes tires.As far as carpets go I use folex it can found at Lowes or Home depot.
Tim "I have done so much with so little for so long. Now I can do anything with nothing"
Super Member
I've used it on interiors, cut to 4:1. Leaves a nice finish, nothing that would cause glare to the driver. Non oily. Good stuff.
Kyle
Originally Posted by Dugdug
Anyways, a customer with a hummer asked me if there was a surcharge for his hummer. I said yes, it's an SUV. He said quote "well it's an H3, so it's not really an suv".......
Super Member
I love HD, use it on tires/engines and interiors. For interior I do 3:1...its still not super shiny but gives a nice satin look which i like for interiors.
Folex is good stuff...also I like to use Megs APC or APC+ diluted about 5:1.
All 3 can be used on carpets or fabric seats/arm rests.
Best way to clean those areas depends on your tools...do you have a shampooer? If not do you have a shop vac? If you do then spray folex or APC onto the area (after vacuuming that area first)...let it set for a minute and then use a brush to scrub it. I keep a clean bucket of water to rinse my brush out in so that way i dont end up scrubbing the dirt on the brush back into what i WANT to clean. Then vacuum it up if you have a shop vac or extract if you have a shampooer.
If you DONT have those machines...then used a MF towel or a terry towel to sort of blot the area dry as best as you can. Hope that helps...good luck!
Super Member
If you buy Folex get it in the Gallon..much better value.
When using Folex don't scrub with a brush. Put on some nitrile gloves and scratch the surface with your finger or blot with a towel.
Sent using Tapatalk
"Challenge yourself to live a better tomorrow than you did yesterday"
thnaks for everyones help
I hav ea small wet/dry vac. I think it should ok to use.
I also have Bissel hot water, heavy traffic soil remover.
I guess this would work ok too.
I have a small wet/dry vac.
I also have a bisell litle green machine, its ahot water machine that is for spot cleaning
Super Member
Sent using Tapatalk
On why you should not scrub Folex with a brush.
Similar Threads
By Coopers ST in forum Auto Detailing 101
Last Post: 03-26-2016, 04:51 PM
By jgibson2980 in forum Product Reviews
Last Post: 07-25-2012, 11:26 PM
By PA DETAILER in forum Product Reviews
Last Post: 05-22-2012, 05:47 AM
By 08krewkab in forum Auto Detailing 101
Last Post: 02-10-2012, 08:57 PM
By Anderson in forum Auto Detailing 101
Last Post: 01-10-2010, 11:42 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
