Dislikes: 0
Help! Holograms.
I'm working on a 2007 black metallic Dodge Magnum RX, Hemi. It has swirls and holograms. I used my Flex 3401 on speed 2 1/2, Meguiar's MF polishing pad & D300, still have holograms. Switched over to Griog's 6" on speed 4 with Meguiar's MF cutting pad & D300, still have holograms. Then tried Griot's, Meguiar's cutting pad and M105, still have holograms. Went back to Flex with Meguiar's MF cutting pad & M105, still have holograms.
I have not used any polish yet because I thought i should have the holograms out by now. Will polishing get the holograms? I don't know what to do now?
BTW, this is my bosses car.
Super Member
A light polish with a softer pad will get most holograms out. For examples, megs 205 with a white ccs pad took out the swirls I put in my moms black equinox with megs 105 and an orange pad.
If they arent too bad, you might even wanna try a light polish with a finishing pad. Especially if the paint is on the softer side.
Re: Help! Holograms.
Thanks for the info, Kaleb. I think I'll try Meguiar's MF finishing pad and D301 tomorrow, hope that works. If not I'll jump over to M205 and see what happens.
It really was getting frustrating, 105 heat index here didn't help either.
Super Member
105 is some tricky stuff.
Make sure you do a test spot with the finishing disk. I have issues with softer paint and the MF disks.
Super Member
I use a Makita 9227c, when I get any Holograms I use Menzerna 85rd and Gray LC pad.........works like a charm every time.
Vision Detailing
Richmond,KY.40475
859-623-4435
Super Member
+1
Unfortunately, I don't know how to properly use a rotary. I'd probably make the car look worse, if it's possible. I'll just have to use the tools I have and hope I can get em out. This is the first car I've had with holograms so this is a learning experience.
Super Member
usually..any holograms/hazing can be taken out using a quality finishing or micro polish.
+2
After using the Flex, MF polishing pad and D301 I still had holograms. I must be missing something because I have all the necessary tools. Since I'm using a Flex, I wonder if switching over to a foam pad and M205 would make any difference?
Similar Threads
By chuckk in forum Auto Detailing 101
Last Post: 01-03-2016, 05:18 AM
By MstrJosh in forum Auto Detailing 101
Last Post: 07-25-2015, 12:07 AM
By Nate3420 in forum Auto Detailing 101
Last Post: 06-03-2013, 07:08 PM
By 93fox in forum Ask your detailing questions!
Last Post: 02-07-2011, 10:20 AM
By Goodloe3 in forum Wet-Sanding, Cutting & Buffing
Last Post: 12-20-2010, 12:38 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
