Dislikes: 0
Who has used this ? (DP Product)
DP Universal Clay Lubricant protects the paint while detailing clay removes embedded contaminants.
I bought it on BOGO.
Who has used this, and how does it compare to the "well Known" products that are at time substituted as clay lubes ?
Let me know. Thanks !
Regular Member
Re: Who has used this ? (DP Product)
Worked well for me, didn't streak at all when wiped off. I made the switch to ONR diluted for clay lube though, just because it's a lot cheaper.
Super Member
I've used it and it's a great clay lube. I ran out and started using ONR diluted as my lube. I'll probably stick with the ONR since I'm going to always have some laying around. Either that or the DP rinseless wash. That works really well as a clay lube too.
Could both of you guys post the ratio that you are using ONR for as a clay lube ?
(reason I ask is because I see many people mixing there own dilution for this)
also, for the DP rinsless, are you using the recommended ratio on the side of the bottle ?
Thanks fella's !
Super Member
I personally use usually 1.5-2oz per 32oz bottle.
Super Member
Clay lubricant is nothing more than water mixed with soap, scents, and coloring. It's principle is to provide a film of solution between the clay and the paint so it doesn't stick.
A solution of 1 to 2 ounces of your favorite car wash combined with 30 ounces of water works just as well as the lubes available for sale.
BobbyG - 2004 Millennium Yellow Z06 Corvette
Regular Member
same
I bpughtnit on BOGO last time and infant to honestly say I an not impressed with it-could be slicker. The sprayer fouled the first time I used it-is that normal, dunno. I will use it until it's gone but wint but anymore.
DP is still a good product line though.
Similar Threads
By BudsJLM in forum Show N' Shine
Last Post: 02-22-2013, 08:15 AM
By SeaJay's in forum Auto Detailing 101
Last Post: 09-29-2012, 12:28 AM
By Swimmer in forum Ask your detailing questions!
Last Post: 04-26-2011, 04:35 PM
By oldmodman in forum Ask your detailing questions!
Last Post: 04-14-2010, 09:08 AM
By scottgt in forum Show N' Shine
Last Post: 04-21-2007, 08:49 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
