Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Super Member builthatch's Avatar
    Join Date
    May 2008
    Location
    east coast
    Posts
    2,352
    Post Thanks / Like
    diamondite glass resurfacing creme and LC glass polishing pad - what to do with it all?
    i've had this bottle and pad for a couple years and i have yet to use either. the creme has grit in it, as a good glass polish should. is it too harsh for glass water spots?
    the pad, well, it's a very strange composition. it's dense and sparkles...for real.
    i've searched the heck out of this forum and found that people were using M04 and a rotary for a while, maybe still are, for water spots and killing it.
    i've read about the DP glass polish, again, for water spots. but some people said it wasn't aggressive enough.
    so, anyone use the diamondite creme with success for water spots and if so, with what?
    what about this funky LC glass pad i have???
    i have the following at my disposal:
    PC with every 5.5/3" pad color available (yellow up to red), no wool/foamed wool
    9227c with plates for the above pads
    which reminds me: can i use any of the pads and tools i have with optimum compound to get rid of the spots without micro marring the glass?
    thanks.
    '09 Mercedes-Benz C 63 AMG / '14 Audi Q5 3.0 S-Line / '99.5 Pathfinder SE
    I DO NOT support or recommend Oakes.
  2. #2
    Super Member Shane731's Avatar
    Join Date
    Dec 2009
    Location
    Madison, AL
    Posts
    3,498
    Post Thanks / Like
    Re: diamondite glass resurfacing creme and LC glass polishing pad - what to do with it all?
    I've had good success using M105 on an orange 5.5 inch CCS pad to remove water spots:
    before
    after (pardon the dust)
    Shane
    2021 Honda Civic Hatchback EX Lunar Silver
  3. #3
    Join Date
    May 2008
    Location
    east coast
    Posts
    2,352
    Post Thanks / Like
    Quote Originally Posted by CieraSL View Post
    before
    http://www.autogeekonline.net/forum/../gallery/data/500/medium/P8070353.jpg
    http://www.autogeekonline.net/forum/../gallery/data/500/medium/P8080354.jpg
    looks great! thanks. on a rotary, i assume?
  4. #4
    Join Date
    Dec 2009
    Location
    Madison, AL
    Posts
    3,498
    Post Thanks / Like
    Quote Originally Posted by builthatch View Post
    Nope. Actually, that was with my Meguiar's G110v2.
    Shane
  5. #5
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,166
    Post Thanks / Like
    Here's the description of that pad: Lake Country 5.5 Inch Glass Polishing Pad
    I used that creme with the thin white hard pad on my Flex rotary to take scratches out of my friend Jr's windshield. I believe I tried the yellow foam glass pad on my PC or Flex 3401 before I resorted to the rotary...but I'd think it'd work pretty well on the water spots. It's a little confusing if the abrasives are built into the pad...why you need to use a polish at all...anyway....
  6. #6
    Super Member S2K's Avatar
    Join Date
    Jul 2010
    Posts
    990
    Post Thanks / Like
    I used the DP Glass Restorer on my badly waterspotted mirrors and it worked wonders. I just applied it with a terry cloth towel and minimal pressure.
    before:
    [IMG][/IMG]
    after:
    [IMG][/IMG]
  7. #7
    Mike Phillips
    Guest
    The answer is "no" but the caveat is how you apply a product is a factor, as long as you apply using something that also won't scratch glass then neither product is going to scratch the glass.
    The pads do work with the creme to remove scratches of glass when used with a rotary buffer, it's a little messy but it does work and it will or at least should remove water spots also.
    This gets back to the type of water spots we're dealing with. The spots on your glass are Type I, that is they are a deposit on the surface.
    So often people think their car paint has Type I when in reality they have Type II, that is the spot is actually an etching "in" the paint and that means you'll need to abrade the paint, not simply clay it or use vinegar on it.
    Since glass is pretty much impervious to chemical attack the spots are almost always topical, or Type I Water Spots.
    Quote Originally Posted by built hatch View Post
    That all comes from me and posts on MOL and I've explained this for more than a decade now... M04 uses a macroscopic diminishing abrasive, it's the "chunkiness" that works to remove Type I water spots off glass and the type of diminishing abrasive used in the M04 doesn't scratch glass.
    Background: Lived in Oregon most of my life, it rains a lot in Oregon, as a detailer you cannot restore the shine to the paint but leave the glass covered with water spots, since I always had M04 with me I found that it worked well by hand or with a rotary to remove water spots off glass without scratching.
    Other products can and will but in my experience not as well as a chunky product. M105 has abrasives but they are microscopic in size, does it work? Sure but so would spit and a terry cloth towel with enough elbow grease. It's the chunky factor that is responsible for the actual abrading off of the bonded minerals and built-up road grime. There's a thread about all this on MOL that goes into absolute depth on the issue. It's in Hot Topics I believe.
    I've only used it once for water spots and it did work, but application material and process are aways factors as it relates to how aggressive a product is or isn't.
    Seems to work well for removing scratches in the glass when used with a rotary buffer.
    Wool pads work best for removing water spots off glass with some type of compound or glass polish. An aggressive foam cutting pad can work depending upon the polish. Might have to experiment or do a test spot.
    thanks.
    I always recommend doing a test spot to an inconspicuous area first, don't just try any product pad combo out right where the driver looks through the windshield.
  8. #8
    Join Date
    May 2008
    Location
    east coast
    Posts
    2,352
    Post Thanks / Like
    Quote Originally Posted by Setec Astronomy View Post
    exactly. i got it originally because of that unusual feature, but i've yet to use it for that very reason.
    mike, thanks a ton for your detailed answers. i'll play around and see what's doin'. this is the exact reason why i hate collecting stuff because i'm a creature of habit- when i find something that works i stick with it until they don't make it anymore, and using new stuff isn't in my DNA. but i'll try these items.
  9. #9
    Newbie Member MID's Avatar
    Join Date
    Sep 2010
    Posts
    5
    Post Thanks / Like
    use some time of window cleaner or just soapy water or just water with a razor blade, i use it for when i tint windows to get a clean surface and takes out water spots with ease
  10. #10
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,095
    Post Thanks / Like
    Quote Originally Posted by MID View Post
    It might be easy on interior spots, unless you tint windows from the outside.
Similar Threads
  1. Replies: 17
    Last Post: 02-01-2017, 05:08 AM
  2. auto glass resurfacing?
    By Spawne32 in forum Off-Topic
    Last Post: 08-13-2013, 11:17 PM
  3. When will Diamondite Glass Resurfacing Creme be back in stock?
    By Calibmw23 in forum New Car Care Products
    Last Post: 07-26-2012, 08:30 PM
  4. Diamondite Glass Polishing On Truck U
    By Mike Phillips in forum Autogeek on Velocity Channel TV
    Last Post: 02-13-2012, 03:30 PM
  5. Thanks Meghan - Diamondite Glass Creme BMW Headlights
    By Totoland Mach in forum Auto Detailing 101
    Last Post: 12-29-2007, 01:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
