Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 77
  1. #11
    Super Member TheGLL's Avatar
    Join Date
    Aug 2009
    Location
    Montreal, Canada
    Posts
    514
    Post Thanks / Like
    Re: The benefits of a light paint cleaner, cleansing lotion or pre-wax cleaner
    Great write-up Mike!
    Question....
    Is Dodo Juice Need For Speed Cleaner Wax considered a paint cleaner ?
    Because I would like to use it to clean my paint, than add a coat of Klasse sealant and a coat of Collinite 845 wax.
    Thanks.
    Guillaume is my name.
  2. #12
    Mike Phillips
    Guest
    Quote Originally Posted by TheGLL View Post
    Question....
    Thanks.
    Technically it's a cleaner/wax...
    Lots of people use cleaner/waxes as paint cleaners...
    It's all good...
  3. #13
    Join Date
    Aug 2009
    Location
    Montreal, Canada
    Posts
    514
    Post Thanks / Like
    Quote Originally Posted by Mike.Phillips@Autogeek View Post
    It's all good...
    Great, thank you!
  4. #14
    Super Member AndrewBall's Avatar
    Join Date
    Sep 2010
    Location
    West Chester, PA
    Posts
    286
    Post Thanks / Like
    is it still necessary to use a paint cleanser or pre wax cleaner prior to applying a sealant if you just Compounded and Polished?
    i dont have any in my tool bag right now but i was thinking i should grab some Pinnacle Paint Work Cleansing Lotion.
  5. #15
    Mike Phillips
    Guest
    Quote Originally Posted by AndrewBall View Post
    No.
    It's an either/or situation.
    It works really well and is easy to use and wipe off.
    How to clay, clean and wax paint by hand with Pinnacle Paintwork Cleansing Lotion and Pinnacle Signature Series II Carnauba Paste Wax
  6. #16
    Regular Member OZD 35's Avatar
    Join Date
    Mar 2010
    Posts
    143
    Post Thanks / Like
    Quote Originally Posted by forrest@mothers View Post
    Our Pre-Wax Cleaner can be used with a DA. I'd suggest a polishing pad (a white Lake Country, which is what I use, as a point of reference).
    We don't recommend Scratch Remover with a machine.
    In both cases, there is a better choice in our consumer line for machine use - our 08616 Power Polish. It's made for use with a DA or rotary. Of course, AutoGeek stocks it:
    Mothers Power Polish
    Hope this helps.
    Does anyone know what speed to use when using this product??? I'm using a Griot's DA.
  7. #17
    Just call me Mr. Mom
    Join Date
    Dec 2009
    Location
    STL and SoCal
    Posts
    767
    Post Thanks / Like
    Which product? Pre-Wax Cleaner or PowerPolish?
    If Pre-Wax Cleaner, start out at about a 2 or 3 to spread, then run it up to its highest setting for a few passes back and forth.
    Be sure to stop the machine fully before lifting it off the paint surface to prevent slinging.
    PowerPolish would be in the same manner, but you can run the passes back and forth longer on the high settings, giving the product more time to work. Since Pre-Wax Cleaner wasn't really made for use with a machine, it will haze quicker, cutting down on useable time.
  8. #18
    Join Date
    Mar 2010
    Posts
    143
    Post Thanks / Like
    Sorry...
    I'll be using the pre wax cleaner.
  9. #19
    Junior Member indianaryan's Avatar
    Join Date
    Sep 2010
    Location
    Kansas City, MO
    Posts
    81
    Post Thanks / Like
    So what I got out of this is that it's best to use a paint cleaner or polisher before each instance of applying a wax/sealant, correct? Say I apply a sealant every 3-4 months, is it necessary to prepare the paint each time this is done?
  10. #20
    Mike Phillips
    Guest
    First since this was your first post...
    Welcome to Autogeek Online!
    Quote Originally Posted by indianaryan View Post
    If your car is a daily driver and not parked inside a garage or some kind of cover, then if you wait for 3-4 months to apply the next coat of wax then "yes" it's a good idea to use some kind of polish or paint cleaner to perfectly prepare the paint for application of wax or a paint sealant.
    Or use a cleaner/wax, which will clean the paint, polish the paint and leave it sealed and protected at the same time.
    If the car is a daily driver and parked out side all or most of the time you should also inspect it to see if it needs to be clayed...
    From my article list in my Signature Line
    Using Detailing Clay
    The Baggie Test - How to inspect for above surface bonded contaminants
    The 2 primary benefits of using detailing clay to clay paint
    Tips and Tricks for using detailing clay
    Do I need to wash my car after I use detailing clay to clay the paint?
    How often do I need to clay my car?
Similar Threads
  1. Pinnacle Paint Cleansing Lotion Leaving Light Haze
    By 65vw in forum Ask your detailing questions!
    Last Post: 09-11-2015, 12:14 PM
  2. Paint cleansing lotion - no. of pads
    By emmjay in forum Ask your detailing questions!
    Last Post: 06-11-2015, 12:38 PM
  3. Pinn Paint Cleansing Lotion vs Adv Fin Polish?
    By MinnBobber in forum Ask your detailing questions!
    Last Post: 08-10-2012, 05:10 PM
  4. Clay bar or Pinnacle paint cleansing lotion
    By Ztandem in forum Auto Detailing 101
    Last Post: 09-09-2010, 01:05 PM
  5. PR: Pinnacle Paint Cleansing Lotion
    By sullysdetailing in forum Product Reviews
    Last Post: 12-09-2009, 05:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
