Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Junior Member Shinystang's Avatar
    Join Date
    Feb 2007
    Posts
    36
    Post Thanks / Like
    Damp sanding RESULTS with pics...
    Purchased a black '79 T/A with a 20 yr old repaint. Flat surfaces were very rough and heavily oxidized. Polishing with Megs 105 clogged the w4000 with a black gum. Results were mediocre at best.
    After seeing Mike's damp sanding article, decided to try 1500 & 3000 on the PC.
    I'm not an expert and I do this for fun only. I was pretty impressed with the results and the speed. Please pardon the rest of the car. I have only done the hood....the rest still looks rough and is covered in compound.
    1. Wash & IP wipedown
    2. Water only spritz on surface and 1500, then 3000 with 4 section passes per area
    per sanding disk, PC speed @ 5.
    3. Megs 105 on w4000 @ 1500 rpm
    4. Megs 205 on Megs yellow 2.0 foam pad @ 900 rpm
    5. Menzerna po85 by Flex 3401 on gray foam, speed 5
    6. Natty's Blue on sponge applicator
    Oxidation AFTER rotary attempt to remove
    Damp sanding RESULTS with pics...-p6220159-jpg
    Left front hood after damp sanding
    Damp sanding RESULTS with pics...-p6220163-jpg
    Left front hood after Megs 105 on w4000
    Damp sanding RESULTS with pics...-p6220165-jpg
    Left front hood after Natty's Blue
    Damp sanding RESULTS with pics...-p6220166-jpg
  2. #2
    Super Member cobalt9123's Avatar
    Join Date
    Apr 2010
    Location
    Georgia
    Posts
    903
    Post Thanks / Like
    Re: Damp sanding RESULTS with pics...
    Nothing inbetween the 105 and Natty's?
    2009 Summit White Cobalt SS/TC SOLD
    2007 Black Cobalt LT - Daily Driver
  3. #3
    Super Member evilwrx's Avatar
    Join Date
    Feb 2007
    Location
    Charlotte, NC
    Posts
    226
    Post Thanks / Like
    Great transformation... how long did this process take you on that section of the hood?
    2006 Honda Ridgeline Nighthawk Black Pearl with the wonderful soft Honda clear....
  4. #4
    Mike Phillips
    Guest
    You're results look amazing, looks like you'll be able to salvage that paint job after all!
    This is what I always call,
    Taking your car's paint to it's maximum potential
    What this means is you do everything you can to get the paint you already have to look as good as it can and while it might not always turn to be a 100% perfect paint job, you take what you have to work with to 100% of it's maximum potential.
    Good job...
    Now lets see if we can take those thumbnails to their maximum potential but uploading them to the gallery so they have an actual "Internet Address", call an URL Address and then we can "Insert" them, instead of "Attach" them and it makes it more enjoyable for everyone to view the results.
    Hang on... lets see how fast I can do this...
  5. #5
    Mike Phillips
    Guest
    Here you go...
    Again... nice work...
  6. #6
    Mike Phillips
    Guest
    That took me about a minute...
    For anyone interested in dampsanding or colorsanding or wetsanding...
    Wet-sanding, Color-sanding & Damp-sanding
    Damp-Sanding Tools, Tips and Techniques by Mike Phillips
    For anyone wondering how to "Insert" and image instead of "Attaching" a thumbnail...
    How to upload a photo into your Autogeek Photo Gallery
    How to insert an image from your photo gallery into your message
Similar Threads
  1. Damp Sanding question
    By mwoywod in forum Wet-Sanding, Cutting & Buffing
    Last Post: 04-17-2017, 09:33 PM
  2. wet/damp sanding
    By KB in MD in forum Wet-Sanding, Cutting & Buffing
    Last Post: 12-16-2014, 06:37 AM
  3. Damp Sanding with the GG6"
    By HUMP DIESEL in forum Auto Detailing 101
    Last Post: 04-23-2014, 07:16 AM
  4. Damp sanding
    By Jeepster19 in forum Ask your detailing questions!
    Last Post: 11-20-2013, 02:20 PM
  5. Damp sanding headlights with a DA?
    By WRAPT C5Z06 in forum Auto Detailing 101
    Last Post: 08-02-2011, 11:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
