Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 9 of 9
  1. #1
    Newbie Member
    Join Date
    Mar 2009
    Posts
    2
    Post Thanks / Like
    Wheel cleaning question
    Wheels are on my 1984 Porsche 928S which I have owned since new. The clear coat is worn off and a well meaning detailer apparently sprayed wheel cleaner on them in the hot sun. Disaster immediately. They now look worse than they have every looked. White streaks dripping down which dried. I guess he tried to get them clean but couldn't. I refrained from expressing myself with tremendous self restraint. I believe the wheels are aluminum.
    Suggestions on what to use on them at this point would be appreciated. I will be doing the work. I have a new Griots machine and all the pads I might need. I am thinking I need a product which will remove the damage and polish.
  2. #2
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,100
    Post Thanks / Like
    Re: Wheel cleaning question
    Looks like you'll have to have them refinished. Any pictures? Opps, first post.
  3. #3
    Super Member Jimmie's Avatar
    Join Date
    Dec 2006
    Location
    Upper Desert, CA
    Posts
    4,349
    Post Thanks / Like
    Quote Originally Posted by Rsurfer View Post
    . Never experienced it firsthand but have heard enough stories on here to think that whatever product he used stained them. Sorry. It has caused some companies to develop a product just for aluminum. Hope that there is an easier answer. Maybe someone will chime in with a solution.
    OH, and too.
  4. #4
    Super Member 2003 GMC Denali's Avatar
    Join Date
    Jun 2009
    Posts
    501
    Post Thanks / Like
    Sucks about your Rims !
    AUTOGEEK sells this product...
    Wurth Silver Wheel Spray Paint
    Also, post your thoughts on the new Griot Buffer when you get a chance. I`d like to hear about a fellow Griot`ers experiences.
    Dean
    Edmonton, Alberta, Canada.
    2003 GMC Sierra Denali
    Onyx Black/Pewter Leather
    w/AWD & QuadraSteer.
    2008 Infiniti EX35 AWD
    Aspen Pearl/Black Leather
    w/AWD & Journey Pkg.
  5. #5
    Super Member ScottB's Avatar
    Join Date
    Mar 2006
    Location
    South Florida
    Posts
    18,803
    Post Thanks / Like
    uncoated wheels will stain and etch rather easily with acid based washes. I would have them sent out to be professionally refinished as they will always be an eye sore to you. You can try a metal polish and fine steel wool (quad zero) but tread lightly.
  6. #6
    Super Member
    Join Date
    Mar 2009
    Posts
    1,268
    Post Thanks / Like
    Quote Originally Posted by killrwheels@autogeek View Post
    What about brass wool?
  7. #7
    Join Date
    Mar 2006
    Location
    South Florida
    Posts
    18,803
    Post Thanks / Like
    I would tread very lightly ... dont know the cut/rating of brass wool.
  8. #8
    Junior Member
    Join Date
    Jul 2009
    Posts
    61
    Post Thanks / Like
    You are actually talking about BRONZE wool. I use it around the house where I do not want the rusting problem with steel wool. I honestly do not know how it would fair on aluminum wheels.
    Have you considered polishing the wheels? It seems like many folks go for the high shine once the wheels start to corrode. Does the acid etching look like the white corrosion that forms under clear coats?
    I fear though, if you want a machined look to the wheels, you will have to send them out to be re-cut.
  9. #9
    Super Member
    Join Date
    Jul 2008
    Location
    Roanoke, Va.
    Posts
    209
    Post Thanks / Like
    I had polished aluminum wheels once which I sprayed the wrong cleaner on. Got white streaks immediately. Nothing would touch them but aluminum polish. I believed I used Mothers, cleaned them up well. But I would think a detailer probably knows this and tried this, so it could be a different problem.
Similar Threads
  1. Replies: 21
    Last Post: 11-30-2017, 01:00 PM
  2. Wheel Cleaning Question
    By mmeachem in forum Auto Detailing 101
    Last Post: 07-12-2011, 08:21 AM
  3. Wheel cleaning question...
    By WRAPT C5Z06 in forum Auto Detailing 101
    Last Post: 03-24-2010, 07:48 PM
  4. Wheel Well Cleaning Question
    By SRHTX in forum Auto Detailing 101
    Last Post: 12-20-2009, 08:37 AM
  5. Wheel Cleaning Question
    Last Post: 05-26-2009, 04:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
