Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Newbie Member
    Join Date
    Jun 2009
    Posts
    22
    Post Thanks / Like
    Dewalt setup to remove 2000 grit
    2000 grit wetsand on clearcoat. What packing plate and foam pad should I buy. I am using XMT #4.
  2. #2
    Junior Member Sellncars's Avatar
    Join Date
    May 2009
    Location
    Upstate, NY
    Posts
    48
    Post Thanks / Like
    Re: Dewalt setup to remove 2000 grit
    Quote Originally Posted by regal View Post
    Honestly i have the same buffer, it is a great tool. I started with all wool pads on a 7" backing plate, then just recently bought a 6" backing plate so that i could use my 6.5" foam pads that i bought for my PC, either will work great, i like the 6" better though, that's just me though.
    Good luck,
    Sellncars
  3. #3
    Newbie Member
    Join Date
    Jun 2009
    Posts
    22
    Post Thanks / Like
    Quote Originally Posted by Sellncars View Post
    Good luck,
    Sellncars
    Do you have a link for the 6" backing plate, I have bought so many useless backing plates for this thing I want to make sure I get the right one.
    thanks in advance
  4. #4
    Super Member
    Join Date
    Sep 2006
    Posts
    2,397
    Post Thanks / Like
    thanks in advance
    Rotary Flexible Backing Plate, lake country rotary backing plates, makita 9227 backing plate, dewalt 849 backing plate, circular backing plate
    Really for wetsand marks, I guess use your favorite compound and follow up with your favorite finishing polish. I did recently watch some Meguiars Classes on youtube and the 105/205 combo with wool pads put forth some serious results.
    Autogeek OG. Attended detail fest I/II. Still detailing!
  5. #5
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,097
    Post Thanks / Like
    Why not finish with 3000, less buffing.
  6. #6
    Super Member
    Join Date
    Sep 2006
    Posts
    2,397
    Post Thanks / Like
    Quote Originally Posted by Rsurfer View Post
    Good call on the higher grit.
    @OP was the etching that bad to have to start at 2k grit ?
Similar Threads
  1. Compound selection after 2000 grit
    By JT Moto in forum Wet-Sanding, Cutting & Buffing
    Last Post: 10-03-2021, 10:13 AM
  2. Need advice to remove 2000 grit sanding marks
    By Roan65 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 04-18-2019, 08:34 PM
  3. Sanding through clear with 2000 grit?
    By dannythekid in forum Wet-Sanding, Cutting & Buffing
    Last Post: 04-09-2014, 06:33 PM
  4. Anybody use 2000 grit on the D/A ?
    By adrynalinjunkie in forum Ask your detailing questions!
    Last Post: 11-23-2012, 03:23 PM
  5. How to remove 2000 grit sanding marks completely?
    By zckid in forum Auto Detailing 101
    Last Post: 03-07-2012, 08:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
