Dislikes: 0
Is Polishing Compound Directly Related With Polishing Pads
Hi,
I need some expert to advise me on choosing the type of pad vs the polishing compound? Is the pad or the compound doing the cutting? As i encounter in difficult in removing the water mark?
Super Member
Re: Is Polishing Compound Directly Related With Polishing Pads
both do the cutting... as far as foam pads do, you can use a Yellow or an Orange LC pad for compounding. If either of those fail you, then you will need to step up into a wool pad. The Purple Foamed Wool pad is a good one to start out with
Super Member
pads and polishes are both abrasive, and to varying degrees. You gotta pick the correct combo.
Super Member
I have a noob question to add to this. From reading on here, it seemed that an orange pad and SIP would basically cover the most aggressive that I would need in my arsenal or hobby detailing. Am I wrong in this regard? I am having a tough time cutting down as much as I would like with the Orange pad. I did order a Yellow pad, but I am a little reluctant to use it, am I just being too cautious?
Super Member
I would pefer to up the polish to Powergloss, but since you ordered the yellow pad, give it a try. It will probably cause some hazing and you will need 106 to finish down.
Hi,
Can you advise me what the different between compounding pad & foam wool pad?
SELF BANNED
A foam wool is going to cut a little better and faster. A full wool pad will give you the best cut and it levels the paint the best. I would also try to pick up some M105, M95, or powergloss for the tough swirls. I feel if you are going to go as far as using a orange or yellow pad you might as well get a wool pad. They are much easier to use and like I said above they cut better and level the finish so you can move on to your final polish step with a better preped surface.
Hi guys,
I presently using the following items, can you guys advise me which pad should i use to correct water mark or light swirl?
SSR2
SSR1
Poorsboys Polish
Ex-Sealant
Thank
Super Member
Originally Posted by Justin
Hi guys,
SSR2
SSR1
Poorsboys Polish
Ex-Sealant
Thank
In general using the Wolfgang pads :
SSR2 -- orange pad, or white for lower markings
SSR1 -- white pad, or finishing pad (follow from same)
Poorboys Polish -- (with or without sealant), likely light pads like white or grey
EX-Sealant -- hand application , or finishing pads only (blue as possible)
Hi Rocket,
Which is better to control in term of usage?
Similar Threads
By Joe@NextLevelDetail in forum Auto Detailing 101
Last Post: 06-26-2019, 06:14 AM
By Ferris in forum Auto Detailing 101
Last Post: 05-28-2016, 04:48 PM
By asap2stacks in forum Auto Detailing 101
Last Post: 04-27-2016, 05:46 AM
By Sunder92 in forum Auto Detailing 101
Last Post: 10-09-2014, 08:20 AM
By Lowejackson in forum Auto Detailing 101
Last Post: 12-25-2011, 06:21 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
