Dislikes: 0
Super Member
Re: Issue with ech2o and reload as drying aid
I wouldn't use the combo on a wet vehicle. I do use it as a detail spray though. I spritz it on a damp drying towel, wipe and then buff with a dry one. If you want to use a pure drying aid on a wet car that you will be drying with a towel, I recommend Wolfgang Uber Rinseless mixed up 1ox to 3gals.
2019 Pearl White Accord 2.0T Touring (mine)
2023 Snowflake Pearl White CX-30 Turbo Premium Plus(wife)
2010 Urban Platinum Metallic CRV EX-L & 2014 Mica Black Metallic Toyota Corolla S (kids)
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
Super Member
[QUOTE=JMak97008;1542953]Yeah, I've just started using my shop-vac to blow out the doors, handles, gas, seams between panels and the hood, roof, and trunk lid.
Dragging around a shop-vac doesn't sound very user friendly.
So I'm taking it that you are mixing uber 1oz to 3 gal in a spray bottle? Then I guess you spray some on each panel as you dry?
Super Member
Not the safest way to blow air either.. Would you want to blow air onto your paint at high velocity through your dirty shop vac hose? Me neither.
Super Member
Yes but honestly I've changed my technique on my personal vehicle when drying. I use a leaf blower to remove 99% of the water from all the seams and surfaces then I use a clean 16x16 480GSM Rag soaked in the Uber Solution at 1oz to 3gal ratio to dry. Key is to completely wring out the towel so that it is just damp. From there I simply spritz my ECH20 and Reload detail spray (when I choose to use it) on the surface of the rag and give it one last squeeze. I don't use but a few sprays. Wipe the panels off completely then give it a quick buff/pass with a dry Car Pro 16x16 Suede cloth. The same ones I use to remove my coatings. They are the only rag that I have found to be truely 100% lint free and on my pure black car, I'm OCD about things when I finally get them clean and dry Other colors won't show lint hardly at all thus I really only use them where needed.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
Super Member
Reload will, or has been known to cause streaking in the past. I haven't heard of people having that issue recently, but I suppose it's possible. Shake the living daylights out of the product. When you're not spraying, you're agitating. I noticed this helped with Reloads application, especially when the new version launched in '14. This may help.
I use this exact drying method usually. I get most water with a big 1200gsm towel. Then, I mist the panels. Using my Griot's garage PFM towels I dry the car. There is some streaking sometimes, and I mediate this by just going over the whole car quickly with a dry, edgeless plush towel. Adds time to the process, but it's my car and the weekend anyways so whatever.
2019 GLI 35th Edition DSG in Pure Grey w/ OEM+ IS38 turbocharger and various bolt-ons.
Lugging around a 16 gal shop-vac in my driveway isn't very hard at all. But I'm just a weekend warrior detailing my personal cars. Metro across looks cool and all, but I want to spend my money on multi-purpose equipment and products.
Hadn't thought of it that way... Ironically, this past weekend I did look inside one of the attachment and it was dirty. Didn't think to inspect the hose.
A $20 leaf blower works just fine.
2021 Alfa Romeo Giulia Ti
2017 Honda CTX700
IG- alfaromeogiulia.palmbeach
Post Thanks / Like - 1 Thanks, 2 Likes, 0 Dislikes
07rs thanked for this post
Regular Member
I find ECH2O very streaky, to the point that I've stopped using it. I have had better results with Reload when applying by spraying on the high pile side of an MF towel, applying it to the vehicle using the towel, then buffing off the with the pile side.
If you are looking for a drying aid that's hydrophobic and doesn't streak, I've found Chemical Guys After Wash to work well. If you're looking for a quick detailer that doesn't streak at all, I have found 3D HD Touch to be totally streak-free.
Similar Threads
By MrOneEyedBoh in forum Auto Detailing 101
Last Post: 10-27-2018, 08:37 AM
Last Post: 08-12-2018, 10:06 PM
By Whacky in forum Auto Detailing 101
Last Post: 03-15-2018, 09:41 AM
By Whitewater25 in forum Auto Detailing 101
Last Post: 01-23-2017, 12:28 AM
By Matt@flyingchipmunk in forum Product Reviews
Last Post: 01-13-2017, 10:57 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
