Dislikes: 0
Re: can I apply a coating over Carpro Essence a few days after??
Originally Posted by BadgerRivFan
You can absolutely apply your coating over Essence a day or two later... you'll need to ensure the paint is perfectly clean though to get the desired result.
Will the vehicle be driven? Or remain parked in a garage?
It would need a wipe down with something like Eraser or Gyeon Prep, etc. prior to coating.
If you have driven the car, cleaning it first with N-914 (or D114 if you have any) then a final wipe down with Eraser/Prep would be advised.
Keep in mind the more you touch the car the greater the chance of marring the paint.
Best to leave it parked inside for the time between applying Essence and when you are ready to install the coating.
Thank you for your response! The vehicle will be driven so yes definitely another decon is needed prior to coating. Definitely a reset wash and a iPa/eraser wipe down prior to coating. I just wasn't sure because essence does have some sio2 so wasn't sure how bonding/merging would be affected. Have a great weekend
Just to clarify my comment... I agree that it is unnecessary to do an Eraser wipe down when going from Essence to one of the CarPro coatings (after an hour of cure time according to CarPro), however the OP did not indicate which brand of coating he had intended to use. I was actually thinking more in terms of the time between polishing with Essence and applying the coating. Even if the car is sitting in an enclosed garage you are likely to get some dust accumulation and/or debris on the paint over a 24 hour, 48 hour or longer period of time. Best practice would be to have the cleanest surface possible before applying the coating, hence my recommendation to wipe the paint down with Eraser, Gyeon Prep, etc.
Yup sorry I do have a non carpro coating that will go over essence, thanks again
Originally Posted by Ronin47
Essence without any IPA/Eraser etc. has been fine on the many coatings I have used. There has been no adverse effects in durability, gloss etc. Just as Essence Plus has rejuvenated and repaired all types of coatings. I even top Reload with all brands of coatings.
Originally Posted by Rsurfer
Why not do the horizontals completely one day and do the vertical another? If you should get tied up or weather prohibits you from finishing, it won't matter if its days or weeks before you can finish the second half.
Great point! Thank you sir
Originally Posted by Nicholas@Autowerx
The longer you let Essence cure prior to coating the better IMO. I always let Essence cure overnight, Eraser wipe in the AM, and then start coating.
Thanks for the reply, that's great news since essence is going to sit for a few days.
Thanks for the reply, I do the same as well with both my coatings is topping it with reload, I'm pretty addicted to it since it goes on everything, have a great weekend
Similar Threads
By OrangeVee in forum How to Videos
Last Post: 12-29-2019, 03:00 AM
By Donalds detailing in forum Auto Detailing 101
Last Post: 10-26-2017, 08:45 PM
By BadgerRivFan in forum Wolfgang Car Care
Last Post: 08-16-2016, 09:11 AM
By SYMAWD in forum Auto Detailing 101
Last Post: 06-14-2016, 11:04 PM
By Dapper Don in forum Tricks, Tips and Techniques
Last Post: 01-05-2016, 11:57 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
