Results 1 to 8 of 8
  1. #1
    Junior Member
    Join Date
    Aug 2013
    Posts
    37
    Post Thanks / Like
    GG 6" Pad Question
    GG 6" DA w/5 inch backing plate ordered and is en route. I have 2 questions. I have combed over copious threads and feel prepared by all the great posts on polishing. The pad choice is a little bit less clear so let me share the intended use. I'd be interested in hearing some thoughts from you out there.
    1st time user of a polisher that will be maintaining 2 white cars. One is a new vw Passat, paint in great condition, not much correction needed. The other is a 2014 acrua MDX that has light scratches everywhere / spider webbing.
    I have a 32 oz bottle of Wolfgang Uber AIO so I want to use that and keep it simple by not ordering other product if possible. Plan to top with Colinite 845, or Leno Hand Wax. I do clay bar and iron-x to prep surface before doing getting started.
    Ordered the autogeek bundle that includes with 5 inch backing plate and the griot's 5.5" orange foam, 6.5" black foam and 6.5" red foam, one of each.
    What is logical choice of pad selection for my situation?
  2. #2
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,098
    Post Thanks / Like
    Re: GG 6" Pad Question
    The red and black are very similar. You should have a white for polishing. You cannot polish an entire car with one (color) pad. I would get at least 3 orange and 3 white.
  3. #3
    Mike Phillips
    Guest
    Quote Originally Posted by Jertronic View Post
    Great question. You've done your homework.
    The goal when using a one-step cleaner/wax, which is what the Wolfgang AIO is - is to avoid the shadow-effect (micro-marring), when using a one-step on dark colored paints that can be caused by either,
    The abrasive technology
    The pad
    And the key point is, if it happens to black and dark colored paints it's happening to white and light colored paints it's just your eyes can't see it.
    So the best pad is to try to use a polishing pad. In order of aggressiveness with most aggressive to least aggressive,
    Foam cutting
    Foam polishing<--
    Foam finishing
    Foam waxing
    I expound on this idea in the first post of this article,
    How to choose and use a one-step cleaner/wax by Mike Phillips
    So test the Griot's orange pad and see how the paint looks.
  4. #4
    Junior Member
    Join Date
    Aug 2013
    Posts
    37
    Post Thanks / Like
    Helpful feedback on both accounts that will make it easy to order some more pads. Appreciate the guidance guys.
  5. #5
    Newbie Member
    Join Date
    Feb 2019
    Posts
    10
    Post Thanks / Like
    Hello everyone,
    I have a similar question. I have bought Griots Garage 5” conversation kit. I am confused between orange and black pads. I am having Meguiars ultimate polish and compound.
    Orange pad is to be used for polishing or the black one?
    And what for compound ?
  6. #6
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,740
    Post Thanks / Like
    try using the ultimate compound with the orange pad and ultimate polish with the black pad...
  7. #7
    Newbie Member
    Join Date
    Feb 2019
    Posts
    10
    Post Thanks / Like
    Quote Originally Posted by VISITOR View Post
    Thaks VISITOR.
    So should i get some white LC pads for polishing i future?
  8. #8
    Join Date
    May 2007
    Posts
    9,740
    Post Thanks / Like
    the LC white (polishing) pad is right in between the orange and black pad. each paint reacts different so the white pad may be all that's needed with a polish. do a test spot, it would be a good idea to have a handful of different pads as you don't know what to expect...
  9. Thanks surajdhillon thanked for this post
    Likes surajdhillon liked this post
Similar Threads
  1. "Nappa Exclusive Leather" in Mercedes cleaning question
    By dlefty in forum Auto Detailing 101
    Last Post: 02-12-2018, 09:43 AM
  2. Question with regard to a statement you made in thread "7424xp & M101"
    By robwoodgto in forum Ask your detailing questions!
    Last Post: 05-01-2017, 09:37 PM
  3. Type II water spot removal question about "spotless"
    By brondondolon in forum Ask your detailing questions!
    Last Post: 06-09-2014, 09:16 PM
  4. 3" Trizact 3000 Foam Disc and 3" Backing Plate Question
    By Mirror Detailing in forum Auto Detailing 101
    Last Post: 06-10-2010, 02:27 PM
  5. 105 Worked Until "Dry" vs "Dry Buffing" Question
    By MobolWerks in forum Ask your detailing questions!
    Last Post: 03-10-2010, 10:12 PM
Members who have read this thread: 1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
