Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Super Member mwoywod's Avatar
    Join Date
    Apr 2016
    Posts
    881
    Post Thanks / Like
    Re: Best 3 inch cutting pads
    Quote Originally Posted by Joel1979 View Post
    What makes them better than Megs? I have used Megs, Buff and Shine(old ones with a hole), Lake Country new ones, Flexipads and Rupes. I like Megs, Lake Country and Buff and Shine most. Does Boss mf pad cut more and is more durable than megs? Lake Country and Buff and Shine are very durable. Megs is not asdurable but i still like it.
    Recently started a thread sharing my recent experiences with all of the different MF Pads.
    https://www.autogeekonline.net/forum...iber-pads.html
    To summarize,
    I think the new LC pads are more durable, cut better, and run smoother than the old Megs MF pads
    The buff and shine uro-fiber pads are by far the most durable MF pads I've ever used, are extremely smooth, but will not cut quite as well as the other 3. That said, it is the best best for 1-step compounds and even works well with AIO's like HD Speed and Boss Finishing Sealant.
    Boss is more durable than Megs, but you need to switch them out regularly. It cuts nearly as much as LC an Megs do but runs MUCH cooler. It also finishes nearly as well as the B&S uro-fiber pads. Honestly, I don't understand why LC would release a microfiber pad without a center cooling chamber. I feel that is what really gives the boss MF and uro-fiber pads an edge in performance even though the LC pad is still remarkably durable.
  2. #12
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,728
    Post Thanks / Like
    Quote Originally Posted by mwoywod View Post
    Lake Country HDO Foam Pads
    HDO Fiber Heavy Cutting Pad
    Features a microfiber nap that removes heavy imperfections from your painted surfaces. Like other microfiber pads, it will enough to remove moderate to severe paint imperfections, but finishes like a foam pad.
  3. #13
    Super Member
    Join Date
    Jul 2013
    Location
    Apex, NC
    Posts
    1,283
    Post Thanks / Like
    The Optimum Hyper Wool Pad have a lot of cut if you have not tried them yet. They will leave a bit of haze, but they will out cut a MF pad
  4. #14
    Junior Member
    Join Date
    Apr 2016
    Posts
    65
    Post Thanks / Like
    Wow thanks for sharing all this information. I really appreciate it. Gives me a pretty good idea of which brand to buy next.
    Would MF pads be suitable for a rotary with a 3" soft backing plate? Or should I buy a DA that will have the option of installing a 3" backing plate?
  5. #15
    Super Member
    Join Date
    Nov 2009
    Location
    Pasadena, CA
    Posts
    12,615
    Post Thanks / Like
    MF pads are not popular on a rotary and for very good reason. The work best with a free spinning DA.
    '03 Corvette Z06
  6. #16
    Junior Member
    Join Date
    Apr 2016
    Posts
    65
    Post Thanks / Like
    What would be the best DA polisher for 3"?
  7. #17
    Regular Member
    Join Date
    Aug 2016
    Posts
    199
    Post Thanks / Like
    Rupes mini.
  8. #18
    Junior Member
    Join Date
    Apr 2016
    Posts
    65
    Post Thanks / Like
    I use a the Flex PE-14 which is a rotary polisher. I have the soft 3 inch backing plate. Just looking at my options for the best cutting pads to use with it.
Similar Threads
  1. Flex Precision Pads 1 inch 2 inch 3 inch - IN STOCK
    By Mike Phillips in forum Ask your detailing questions!
    Last Post: 10-28-2015, 08:56 PM
  2. Microfiber cutting pads -- 5 or 6 inch?
    By lysoleverywhere in forum Auto Detailing 101
    Last Post: 10-18-2014, 07:11 PM
  3. Replies: 19
    Last Post: 02-16-2014, 11:49 AM
  4. is megs bp necessary for 3 inch mf cutting pads
    By john b in forum Products Guides
    Last Post: 05-30-2011, 03:51 PM
  5. Replies: 7
    Last Post: 12-22-2009, 05:02 PM
Members who have read this thread: 1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
