Dislikes: 0
Super Member
Re: XC 3401 VRG Backing plate rubbing on ring gear
Originally Posted by Alekss
added pics
Looks perfectly seated. Hmmmmmm.
That's what I thought as well, it is seated correctly, and was like that when I removed it. I always ensure the plate is seated correctly before polishing.
This polishes has been used a few times now (a few cars) and I did use a 6" backing plate with it as well.
The main reason I never used any oil on the felt ring is simply because flex did not specify it, or at least I did not see that in the manual.
Anyway, I will investigate this further and report back.
Thanks for all your help.
If you order a new plate it won't have the metal washer in the middle. The new ones are all plastic and IMO not as good
If it was seated correctly and im not doubting it was ..co tact your merchant for guidance on warranty...
Ive glanced at a few other posts where folks have had flex backing plate issues ...
You will proba ly have to send your unit in for assessment...
Gl and keep us posted
I had this issue with the larger backing plate. I didn't lubricate the felt and this happened, got way worse than this. I was also putting quite a bit of pressure and I don't thing it was flat enough.
Called flex and they sent (or I bought) a new felt ring and backing plate. Lubricated this time and haven't had the issue since.
Similar Threads
By Strip Poker 388 in forum Flex Polishers
Last Post: 06-05-2018, 05:11 PM
By Jeremy1976 in forum Flex Polishers
Last Post: 04-27-2017, 09:12 AM
By Mbout in forum Flex Polishers
Last Post: 02-07-2015, 01:01 AM
By NY-Bondo in forum Auto Detailing 101
Last Post: 03-24-2013, 10:31 AM
By Crazy Amos in forum Flex Polishers
Last Post: 03-03-2013, 05:35 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
