Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
  1. #1
    Super Member
    Join Date
    May 2014
    Posts
    302
    Post Thanks / Like
    Deionizer AND water softener....overkill?
    This year I added a CR Spotless deionizer to help reduce a water spots issue I was having last year. I feel like it greatly helped, but wasn't 100%. The gauge reads that I need to add fresh resin to the deionizer even though I have only used it on about 25 washes (I don't even use it for cleaning wheels/tires/wheel wells). So I was considering adding a separate water filter or water softener system BEFORE the deionizer. I figured my well water was pretty bad, but I have to do something to help conserve the resin in the deionizer since it is so expensive. Do you guys feel like this is overkill or is there something else I can do? I was considering one of the filter systems from Autogeek btw.
  2. #2
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,167
    Post Thanks / Like
    Re: Deionizer AND water softener....overkill?
    That won't achieve what you're looking for. The water softener will leave approximately the same TDS, and the same number of ions, as was in the water before (they will just be different ions, since the water softener is exchanging the hardness ions for sodium or potassium ions), so your CR will not last any longer (give or take). I happen to think 25 washes is pretty good.
    You might want to look into Culligan etc. about renting a larger DI tank that they would exchange periodically. Might even be able to get them to leave you 2 so you change over and call them when the light goes out.
  3. #3
    Super Member frankprozzoly's Avatar
    Join Date
    Mar 2014
    Location
    Pittsburgh
    Posts
    1,596
    Post Thanks / Like
    Shop around you can find cheaper resin. I don't want to get into trouble for mentioning the company
    Sent from my SM-G900P using Autogeekonline mobile app
  4. #4
    Super Member AutoApollo's Avatar
    Join Date
    Aug 2015
    Posts
    209
    Post Thanks / Like
    Quote Originally Posted by 98LowRanger View Post
    I'm on well water and its very hard. Honestly just wash in the shade, and be quick about drying the car down. A quick wax spray will clear up 99% of the water spots before they dry.
    Sent from my Nexus 5 using Autogeekonline mobile app
  5. #5
    Super Member
    Join Date
    Sep 2015
    Posts
    6,281
    Post Thanks / Like
    Quote Originally Posted by AutoApollo View Post
    Agreed only in the shade.
  6. #6
    Newbie Member
    Join Date
    Jun 2019
    Posts
    1
    Post Thanks / Like
    The best water softener I think is the Fleck 5600SXT 48,000 Grain Water Softener. I decided to buy it after checking a lot of information, and it did not disappoint me. Or, if you have a water softener company near your home, you can ask them to test your water quality before deciding which water softener is right for you.
  7. #7
    Super Member
    Join Date
    Jan 2019
    Location
    California
    Posts
    287
    Post Thanks / Like
    The water softener uses minerals to soften the water. But you don't want minerals in your water which is why we use a de-ionizer to remove all minerals, including salt, from the water. I suggest your softener is not helping you.
Similar Threads
  1. Portable water deionizer
    By Azure in forum Auto Detailing 101
    Last Post: 06-15-2020, 12:51 PM
  2. Running Hot Water Through Deionizer
    By medicscott in forum Auto Detailing 101
    Last Post: 06-20-2015, 07:24 AM
  3. Combining Inline softener and deionizer?
    By LaFawnduh in forum Auto Detailing 101
    Last Post: 03-27-2015, 04:03 PM
  4. Idea for homemade water deionizer
    By Divine Details in forum Auto Detailing 101
    Last Post: 09-04-2012, 09:50 PM
  5. AG Water Softener
    By HeavyMetal in forum Product Reviews
    Last Post: 04-05-2011, 08:09 AM
Members who have read this thread: 1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
