Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Regular Member BrianJM's Avatar
    Join Date
    Mar 2016
    Posts
    115
    Post Thanks / Like
    Extent of GG 3" Orbital Polisher v2
    Hey everyone, I purchased the GG 3" Orbital Polisher mainly for small sections of the vehicle and headlight restoration. The other day I just went over my headlights with 105/205 with the foam pads the polisher came with. I felt like I wasn't getting enough rotation from the machine. The question I have is if the GG 3' Polisher IS sufficient enough for restoring headlight or even heavy paint correction? Will it remove sanding marks on headlight or paint when restoring? If I need to get better pads then the ones that came with the polisher. Do you all have suggestions on that?
    Thankyou ALL
  2. #2
    Mike Phillips
    Guest
    Re: Extent of GG 3" Orbital Polisher v2
    Quote Originally Posted by BrianJM View Post
    The Griot's Garage 3" Mini Polisher is a GREAT 3" machine sander. And for this it's great for doing headlight restoration. We sell Mirka Abralon 3" sanding discs and this tool and these discs are a match made in heaven.
    As for removing sanding marks out of headlights get a rotary buffer and a wool pad. For paint correction get a full sized orbital polishers.
    The right tool for the job....
  3. #3
    Join Date
    Mar 2016
    Posts
    115
    Post Thanks / Like
    Thanks Mike, So the 3" GG wouldn't be sufficient for removing sanding marks or paint correcting smaller panels on the vehicle? I also have a PC and Flex 3401
  4. #4
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,170
    Post Thanks / Like
    Put a 3" backing plate on your PC and use 4" pads for spot correction.
  5. #5
    Join Date
    Mar 2016
    Posts
    115
    Post Thanks / Like
    But a dual action polisher will remove sanding marks right?
  6. #6
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,170
    Post Thanks / Like
    Yes, with enough power and the right pad and polish. The GG 3" doesn't have much power, but as Mike noted, it's great for sanding headlights, get the foam interface pads and some Mirka, 3M or Meguiar's discs. Last ones I did I followed the Meguiar's recommendations and went 800 dry, 1000 damp, 3000 damp, then I used 3M Trizact 5000 damp and was able to go to polish after without having to use a compound.
  7. #7
    Join Date
    Mar 2016
    Posts
    115
    Post Thanks / Like
    Nice. Did you use the 4" pads on your PC to polish them?
  8. #8
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,170
    Post Thanks / Like
    Yes, in this instance I used an old blue 1-1/4" thick pad with Optimum Hyper Polish and followed with 3 coats of Opti-Lens. Take that, yellowing! Sorry, it's been a weird afternoon.
  9. #9
    Join Date
    Mar 2016
    Posts
    115
    Post Thanks / Like
    lol THANKS FOR THE INFO BUDDY!
  10. #10
    Join Date
    Mar 2016
    Posts
    115
    Post Thanks / Like
    and by the way what brand sanding discs did you use all the way up to the 5000? Sorry for so many questions
Similar Threads
  1. Replies: 0
    Last Post: 09-25-2017, 04:47 AM
  2. 3" random orbital polisher
    By bryanviper in forum Auto Detailing 101
    Last Post: 10-02-2016, 09:02 PM
  3. Quality 3" Orbital Polisher
    By FinishingTouchA in forum Auto Detailing Tools and Accessories
    Last Post: 07-08-2015, 08:55 AM
  4. GG 3" Orbital polisher for headlights question
    By MoparAddict in forum Auto Detailing 101
    Last Post: 10-12-2013, 12:23 AM
  5. Griot's 3" Orbital Polisher ?
    By Vettecor in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 02-02-2012, 06:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
