Regular Member
Polish before car pro coating
Hello,
Im putting the car pro sic coating on my sisters Lexus this weekend. Does it matter what polish I use as a last step if I use eraser?
Thank you
Re: Polish before car pro coating
Originally Posted by
waterman
Hello,
Thank you
Yes and no. It doesn’t matter which polish but it would matter if it were a one-step polish with protection. Some one steps include 2-4 mo of protection which Eraser wouldn’t completely remove and would interfere with the coating. BF Onestep, HD Speed, Rupes Uno Protect are examples of one steps with protection.
I will also throw out Gyeon Primer and CarPro Essence as SiO2-infused polishes that are supposed to help a coating bond but not sure how true that is. But even with those, you need to use Eraser or similar to remove the polishing oils before coating.
Good luck.
Regular Member
Thank you, I won’t be using a one step. I wanted to order essence but I won’t receive it in time.
Locally Meguiars Ultimate Polish, Meguiar’s D302, Griot’s Perfecting Cream, Meguiars M205/210 are all very good.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
Regular Member
Hello,
It’s funny. I just bought ultimate polish Sunday and already have perfecting cream. I bought ultimate polish on sale because I think this will work very well on my sisters car.
Super Member
dgage
Good luck.
I thought you could coat right over Gyeon Primer? I thought that was one of the selling points of it?
Super Member
briarpatch
PRE COATING PAINT PRIMER
Q² Primer is designed to be used before applying a coating to paint. This coating primer will ensure a long term bond and has laid down a base layer of SiO2 for the main coating to bond to. It will make the coating application smooth and easy.
ELIMINATES NEED TO PREP
If you give 24 hours between the coating primer application and your coating application, you do not need to prep wipe the surface. The main coating will bond perfectly to Primer, and you can avoid any surface marring on soft paints during the prep process.
I used Angel Polish Primer before applying their Cosmic V2 Glass and it was a little different process, you apply the primer and buff it off before applying the glass coat, but no prep
I am just learning a bit about a primer before a coating and have also heard something about a product called essence?
Super Member
Lance Mark
Essence is not only a primer, but a fine polish. It will remove light swirls and scratches and leaves some Sio2 behind.
If you don't work Essence properly, then Eraser should be used before applying a Coating.
Super Member
Lance Mark
+1
I have done this multiple times with good results. But I have also just for curiosity reasons did a prep wipe also one one and noticed zero difference.
I do believe you will like the SiC-- Its been on my Jeep for over a year and you would think I just did it a week ago
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions-- Winston Churchill
The difference between genius & stupidity is genius has limits-- Albert Einstein
Super Member
If your going to polish ( though its not required / necessary - but HIGHLY advisable ) just use a regular polish with no additives. Examples would be Megs 105 / 205 , sonax 04-06 , SchollsS20 black to name a few. The Megs you can just go down to Harbor freight or Auto Zone and they have 'em on the shelf. If You have amazon prime you can get the Megs in 2 days in an 8 ouncer witch will be more than you need for a few cars
Bookmarks
