Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Super Member MrOneEyedBoh's Avatar
    Join Date
    Mar 2013
    Posts
    1,186
    Post Thanks / Like
    Morning dew and coatings, does it matter
    I was just wondering and couldn't find anything via searching, but say you apply the coating the it sits 5-6 hours then gets hit with some dew. Do you think that hinders the coating? Most say no moisture for 24 hours...
  2. #2
    Super Member The Guz's Avatar
    Join Date
    Jun 2013
    Location
    LA, CA
    Posts
    8,719
    Post Thanks / Like
    Re: Morning dew and coatings, does it matter
    It is possible. I once tried using CanCoat and it was exposed to dew overnight. The hydrophobics took a hit as the water beading and sheeting were lacking.
  3. #3
    Super Member
    Join Date
    Sep 2017
    Location
    Sweden
    Posts
    3,022
    Post Thanks / Like
    Not a coating though but happened for me with Ultima Paint Guard Plus. It's has a curing time before moisture can be on it. But the dew came in right away after application. The next wash the water layed flat.
    And I think that SiO2 in it nature absorb water. So as guz mentioned what happened with CanCoat you can experience it could make a dent in the hydrophobic top layer of the coating.
  4. #4
    Super Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    Quote Originally Posted by MrOneEyedBoh View Post
    ...say you apply the coating the it sits
    IMO:
    The main “hindering”, (that may occur if
    the Coating were to get hit with some
    dew/moisture sometime during the initial
    24 hours waiting/(curing) period,) would be
    that the Coating just might not be able to
    achieve the ultimate/maximum level
    of its performance characteristics.
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
  5. #5
    Join Date
    Mar 2013
    Posts
    1,186
    Post Thanks / Like
    Thanks... I dont know what I should do... Im in fear that I might get hit with some dew overnight/this morning... Using M37 paint coating...
  6. #6
    Junior Member
    Join Date
    Jan 2018
    Posts
    61
    Post Thanks / Like
    Apply it first thing in the morning and let it bake in the sun all day.
    Edit: You could also apply the McKee's 37 10 minute paint sealant before the day is over.
  7. Likes SWETM liked this post
  8. #7
    Super Member
    Join Date
    Sep 2017
    Location
    Sweden
    Posts
    3,022
    Post Thanks / Like
    Quote Originally Posted by limited0602 View Post
    This would be a great thing to do. For makeing sure you get the most out of your coating application.
  9. #8
    Join Date
    Mar 2013
    Posts
    1,186
    Post Thanks / Like
    I applied it yesterday and the waited about , 2-3 hours a day applied 10min pain seslant over it. Let's see how it holds up...
  10. Likes SWETM liked this post
  11. #9
    Regular Member
    Join Date
    Feb 2011
    Posts
    196
    Post Thanks / Like
    Sounds crazy but this is the biggest reason im considering making my garage door openings higher.... To fit my truck in so I can let it cure "indoors".
    Sent from my Nexus 6P using Tapatalk
  12. Likes SWETM liked this post
  13. #10
    Super Member
    Join Date
    Jul 2016
    Posts
    3,328
    Post Thanks / Like
    Quote Originally Posted by chris11le View Post
    I was just going to say it's pretty hard to do all this polishing coating stuff outside. You need a day that's dry but not sunny. And not going to create dew overnight. I'm lucky I have a garage to use otherwise I wouldn't be able to do most of the stuff I've done polishing wise.
    I was considering getting a storage unit big enough to detail in if the day ever comes when I don't have access to a garage. At the very least I need one of those covers I forget what they are called. It's like a tent but even then that doesn't really stop everything.
Similar Threads
  1. Replies: 8
    Last Post: 11-06-2020, 10:12 PM
  2. Replies: 1
    Last Post: 11-05-2016, 10:47 AM
  3. No matter what you do...
    By kevincwelch in forum Off-Topic
    Last Post: 02-28-2016, 02:39 PM
  4. Do soaps really matter?
    By Charleston in forum Auto Detailing 101
    Last Post: 11-21-2012, 01:40 PM
  5. Do suds matter
    By Christopher in forum Auto Detailing 101
    Last Post: 07-13-2010, 06:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
