Dislikes: 0
Carpet cleaner question
I just bought the Bissell little green machine and it works great (for me). I would prefer not to use the cleaning solution made by Bissell, but rather the DP Carpet & Upholstery Cleaner as it sounds like a great product. My question is; can the DP be mixed with h2o and if so what solution do you think would work best?
Thanks
www.BISSELL.com - PRODUCTS - LITTLE green(R) Compact, Multi-Purpose Cleaner
Super Member
This isn't going to be the answer that your expecting. I wouldn't mix the DP Carpet but rather spritz it on the carpet, agitate, and then use the LGM to rinse and lift. If I don't care to get the carpet too wet I'll sometimes Spritz on H2O rinse and just use the LGM to lift. Just one guys technique.
That makes sense using the LGM as a rinse. My goal is to let the LGM do all the work as it has the little motorized brush. Do use the attached brush or do it all by hand and then rinse and do you use a scotch guard?
Super Member
Mine's old. Uummm, no, I don't have a motorized brush. Yeah, I'll do almost everything by hand. Example, if I have to really scrub and pressure wash matts I'll use the LGM to lift most of the water. This saves the filter on the wet/dry vac.
The filter shouldnt be in when sucking up water with the wet/ dry vac.
Super Member
Whoooooops. Never knew that. Thanks Dan.
Similar Threads
By Booki in forum Auto Detailing 101
Last Post: 08-04-2017, 04:25 AM
By WRAPT C5Z06 in forum Auto Detailing 101
Last Post: 04-26-2013, 01:03 PM
By SheldonH in forum Auto Detailing 101
Last Post: 06-25-2012, 10:19 AM
By bladerunner in forum Auto Detailing 101
Last Post: 10-07-2007, 06:03 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
