Dislikes: 0
need help first time pc 7424 user
Im going to be detailing my 03 sonic blue cobra. i ordered the following products. poorboys ssr2.5, ssr1, black hole glaze and carnuba moose wax. i need help on the pads i should use and speeds for each step. i have swirls and scratches that im trying to minamize. from what i was told i need to use the ssr2.5 first ssr1 second black hole glaze third and moose wax as the final step.... i ordered the 7424 from here it came with 2 orange pads, two white pads .2 black pads and one blue pad.. thanks for anyfeedback
Re: need help first time pc 7424 user
SSR2.5 + Orange Pad. Then SSR1 + White Pad. Black Hole Glaze by hand, and the Moose Wax by hand.
Be sure to watch the polishing videos that Autogeek.net has posted on their website and on YouTube so you know what you are doing. The PC7424 and the products you have are only as effective as the way you use them.
i would start with the least agressive approach first....start with the white pad and ssr1, if that doesnt get the results you desire, then move to the white pad and 2.5, if no good, then go to the above post....the least agressive the better for the long haul, remove the least amount of clear coat as possible...and also if the least agressive approach works, then it will save a polishing step wich will save time....
you can use the blue pad with the moose wax...
well I already tried the meguirs deep crystal 3 step paint cleaner,polish, wax. I wasn't happy with the results so I did some research and phone calls and ended up getting these products . I also ended up with scuff marks which I waS told is from using to much polish.
Super Member
You can also use your black pad with the Poor boys black hole
Can there be days in between steps. I really don't have the time to complete the detail in one day .
Yeah, provided you don't drive the vehicle. Or you can do what I do sometimes. I'll clean one panel up, such as the hood. Do the paint correction and then seal it up with the wax. And then the next day I'll do the same thing with the next panel. Once the whole vehicle is done, I wash the car thoroughly and then apply another coat of wax.
Similar Threads
By Toolhead in forum Auto Detailing 101
Last Post: 04-13-2017, 12:37 PM
By armorrig in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 11-19-2011, 01:58 AM
By 2kredbb6 in forum Flex Polishers
Last Post: 08-05-2010, 12:02 PM
By emaxxman in forum Auto Detailing 101
Last Post: 12-29-2009, 10:39 AM
By elnandon in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 05-04-2007, 10:21 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
