Dislikes: 0
Super Member
Remove a sticker from a window?
I need some tips on how to get the residue from removing a sticker off my driver's side window. The sticker in question has already been removed, it was a "this product contains chemicals know to cause cancer" kind of sticker that they at least in Ca apparently put on cars now when new.
I remember years ago being told by my parents to "take this bottle of nail polish remover and get the rest of the sticker glue off" after we'd bought a new car but I'm not so sure that's the right thing to use. I was going to try out my Sprayway glass cleaner but wanted to get some tips in case that doesn't work.
FWIW the sticker has now been through 2 1/2 years of northern CA weather and the heat had caused it to start peeling when I rolled the window down. Don't know if that means it will be easier or harder to get the residue off.
Re: Remove a sticker from a window?
Griot's Garage makes a pretty good adhesive remover. You might need multiple applications for stubborn goo, but the product works well.
Super Member
Originally Posted by 07 z-oh-6
Perfect combo!
Super Member
Thanks, any idea if I can find that stuff at a local store somewhere? I'd like to do this tomorrow so it doesn't interfere with my window anymore.
You could use goo gone and a metal or plastic razor blade. Should be able to pick both of these things up at a local hardware store.
Super Member
Scrape as much as you can with a razor blade then dampen a terrycloth towel with mineral spirits and wipe until the residue disappears...
BobbyG - 2004 Millennium Yellow Z06 Corvette
Got any WD-40 around? Really, it will (in most cases) remove the leftover goo.
Discloser: I don't regularly use WD...Goof Off or the like IS my 'go to.'
Bill
Super Member
with what everyone above said.
It can also help to add a little heat before you start even with just a hairdryer.
WD-40 or orange oil with plastic blades and paper towels to break-up and remove the adhesive, then IPA followed by DPS Krystal Vision to clean up the WD-40 and make your glass perfect.
Similar Threads
By Rtrick87 in forum Auto Detailing 101
Last Post: 11-19-2017, 04:04 AM
By Andre in forum Product Reviews
Last Post: 12-12-2014, 02:32 PM
By otruba_843 in forum Auto Detailing 101
Last Post: 04-03-2013, 07:16 PM
By 328ci in forum Tricks, Tips and Techniques
Last Post: 11-28-2012, 11:55 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
