Dislikes: 0
boiling micro fibers?
Ok some one talked about boiling mf is there any tricks or do i just boil them in water?
Super Member
Re: boiling micro fibers?
Simply bring a large pot of water to boil
Add in 2-3 capfuls of white vinegar.
Add a couple towels at a time and allow them to boil.
Try to avoid allowing the towels to sit against the sides or bottom of the pot for too long.
After a few moments pull each towel out (using tongs to be safe) and flush under cool water.
Wash these towels using your usual routine and they should be as good as new.
I usually like to add a little salt and pepper, and serve with some grated parmesan.
Haha i might skip the salt and pepper but vinegar and parmesan sound kinda tasty lol
Super Member
What is boiling them supposed to achieve?
Originally Posted by Jason Rose
I am cursed for life because I can never look at beautiful paint without seeing the defects
Super Member
Not that i know for sure, but i read on a forum that mentioned the naps on mf which absorb water become ineffective after drying them on high heat in the drying machine. They say that the naps basically melt to where they were not as effective as they originally were. Again i dont know if thats true, but i would really like to know so i can try this method out to restore some mf towels lol. Please and thank you
Super Member
LMAO!
"Dry" heat (such as from a clothes dryer) is different to "wet" heat, as is mentioned here.
You are right that fibres can become scorched from too much dry heat but boiling them will be fine.
As camar02ssblack mentioned, probably a good idea to ensure they don't touch the bottom or sides for too long at a time. IMO probably more of an issue for towels on top which may be partly out of the water & touching the side of the pot, effectively dry
Super Member
Here is a link from 2009, when I asked the very same question. Hope this helps.
http://www.autogeekonline.net/forum/...ng-towels.html
Mike !!!
Mid-Michigan
Tri-Cities
So boiling would unmelt the "naps"? MF towels lose their absorptiveness from various types of contamination being held on the fibers, whether that that be detailing products like LSP's and dressings, fabric softener from an oops, or minerals from hard water.
Similar Threads
By muscleman in forum Auto Detailing 101
Last Post: 03-18-2014, 07:53 AM
By bucky92 in forum Auto Detailing 101
Last Post: 03-04-2014, 12:28 AM
By allenk4 in forum Ask your detailing questions!
Last Post: 06-20-2013, 06:17 PM
By WRXINXS in forum Auto Detailing 101
Last Post: 03-21-2013, 02:14 PM
By anson89 in forum Ask your detailing questions!
Last Post: 10-07-2009, 09:58 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
