Dislikes: 0
How long to work compound? Halos on XLR have me befuddled
I am still working on getting these halos out of this XLR I am working on, and I have tried the KBM method with M105/ Burgunday Soft Buff pad, M205/Polishing pad and it seems no matter what combination I am still ending up with fine halos.
The major swirl defects are gone. I Have primed the pads with compound, running at a speed of about 4-5 on the G110, doing about 4-6 passes for about a 2 x 2 area and am moving quite slowly, maybe takes 8-10 secs to do one pass. Should I work the area longer? I am adding just a bit more pressure on top of the weight of the polisher.
Should the compound on the paint still be wet when you wipe it off? I am using a clean microfiber for each section I work on to make sure the MF isn't adding them.
Something with my technique has to be wrong. Maybe I will have my wife film me working a section and I will post it for critique and tips
Re: How long to work compound? Halos on XLR have me befuddled
If the M205 with the Meguiars polishing pad is causing fine swirls, maybe you should try changing the pad to the Meguiars Finishing pad and see if that solves your problem.
Tried that also I may just setup the tripod with the camera and record it myself
only 8 to 10 seconds to do one pass? isn't that a bit fast? try working it longer it maybe break down the abrasives better
but you mentioned you're using 105 and 205 hmm one of their main selling points is that you don't need to break them down you can stop when you are happy with the level of correction as i recall Mr. Mike Pennington mention before
also curious about others answers
I agree with Madkatz. Try working the polish slowly and work it until the polish goes clear. That might help. If that doesn't work, then maybe the paint is soft on the XLR in which you might have to polish using 3M ultrafina or Menzerna SF 4500.
Super Member
M105 has a very limited work time, it could be possible that you dry buffed some.
If dry buffing with M105 caused the halos or micro-marring, shouldn't M205 be able to clean that up?
I think that may be part of the issue, I was outside and it was cloudy and 70 with a good breeze but when I would wipe off the compound it was hazed over like dried wax or sealant.
Should I work even a smaller area then and make sure the compound stays wet when I wipe it off?
When I use M105, I give it a spritz of water to increase the buffing cycle. You could try that.
Reading the doc that Kevin Brown of the KBM method wrote up recommends against using anything like that as it can cause clumping and uneven particles for the polishing.
Similar Threads
By Bhoppy1216 in forum Auto Detailing 101
Last Post: 08-13-2017, 04:42 PM
By CanadianBacon in forum Auto Detailing 101
Last Post: 08-03-2017, 11:09 PM
By Mike Honcho in forum Auto Detailing 101
Last Post: 01-03-2016, 03:46 PM
By Rubyredf150 in forum Auto Detailing 101
Last Post: 08-13-2013, 11:32 PM
By hoyt66 in forum Auto Detailing 101
Last Post: 08-09-2013, 02:54 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
