I wanted to get some fresh insight as how everyone deals with baked-on brake dust on painted wheels with clear coat. I've got a BMW that has stock brake pads and rotors. They have a reputation for a ton of brake dust. The car has only undergone maintenance washing for the last year and I'm thinking that a wheels off deep-clean and coating might be my next project.
This weekend I did a test spot on one of the wheels and was unable to fully remove the embedded brake dust. My goal is to not use any mechanical abrasive process like scotch brite or magic eraser. In addition, additional online research has people using oven cleaner, but I fear that will just eat through the clear coat.
Here's the process I attempted:
1. Saturate area with Meg's 143 Non-Acid Wheel Cleaner 3:1. Gently agitate then rinse.
2. Lightly spray embedded area with Iron-X. Let product dwell for 4-5 minutes.
3. Lightly agitate with a soft bristled detailing brush and wait another minute. Rinse area.
I repeated the those steps three times and was able to remove most of the brake dust, but parts of the wheels in the corners and cervices are still indicating iron contamination. My guess is that the Iron-X is working as it should, but the product is only dissolving one layer of brake dust at a time.
Is there a better way to tackle this? I suppose I could continue using Iron-X until it breaks through the dust, but it seems like I'd use an entire liter of the product to decontaminate all four wheels.
Bookmarks
