Results 1 to 6 of 6
  1. #1
    Super Member
    Join Date
    May 2020
    Posts
    401
    Post Thanks / Like
    Remove/Strip Griots 3-in-1
    I have a small amount of left over Cquartz SiC and want to apply it to my winter wheels for my Edge before I swap them this season. I'm pretty sure last spring I applied a layer of Griots 3-in-1 before putting them away so I want to strip it off before applying the SiC.
    I don't have a lot of products, but I do have some Gtechniq panel wipe and a bottle of 50/50 IPA/water.
    Anyone know if the panel wipe or IPA mix will strip the 3-in-1?
  2. #2
    Super Member RPPM's Avatar
    Join Date
    Sep 2010
    Location
    Reedsville, PA
    Posts
    324
    Post Thanks / Like
    Re: Remove/Strip Griots 3-in-1
    I would use a normal wheel cleaner. Hit it a few times and agitate it well with a wheel brush. You could also use some compound by hand to remove it.
  3. #3
    Super Member Desertnate's Avatar
    Join Date
    Aug 2013
    Location
    St Louis metro (Illinois)
    Posts
    5,855
    Post Thanks / Like
    Have you applied anything to the wheels since last Spring? Are you talking about their ceramic 3-in-1 spray or their 3-in-1 cleaner wax?
    Either way, if you've not applied anything since the original application 6~7 months ago, I'd bet that protection is long gone and there isn't much to worry about. Wheels are a really harsh environment and products have a shorter life there than on regular painted areas. Any protection you applied is likely long gone, so you should be able to get them really clean, hit them with a prep-spray, and just apply the coating.
    Drop by to see the latest at The Car Geek Blog
  4. #4
    Super Member MisterSnoop's Avatar
    Join Date
    Sep 2020
    Location
    Eastern PA
    Posts
    1,824
    Post Thanks / Like
    Quote Originally Posted by Desertnate View Post
    Sounds like this was on wheels that had 3in1 applied and have not been used since then.
  5. Thanks Desertnate thanked for this post
    Likes Coatingsarecrack liked this post
  6. #5
    Super Member
    Join Date
    May 2020
    Posts
    401
    Post Thanks / Like
    Quote Originally Posted by MisterSnoop View Post
    Snoop is correct. I applied the 3-in-1 Ceramic spray in the spring and put them into storage.
    Only thing they've been exposed to is some dust and warm summer days in the attic of our (uninsulated) garage.
    Maybe this weekend I'll take them down and try a few suggestions.
    I'd like to avoid hand compounding/polishing (I only have a GG6), but if that's what is needed, I'll do it.
    The wheels are in really good condition, so they don't really need any correction (at least not worth the time/effort for winter wheels).
  7. #6
    Join Date
    Sep 2020
    Location
    Eastern PA
    Posts
    1,824
    Post Thanks / Like
    Seems like their recommendations on their Q&A is a few rounds of their surface prep, which is high pH. I'd try that or something similar.
Similar Threads
  1. Griots G9: Griots 5" backing plate vs the one Autogeek includes (yellow one)
    By alkemyst in forum Ask your detailing questions!
    Last Post: 04-29-2021, 09:54 PM
  2. How to remove/strip Meguiar’s Hybrid Ceramic Wax
    By Jayfro in forum Auto Detailing 101
    Last Post: 04-19-2019, 09:15 PM
  3. Review: Griots Fine Glass Polish - How to remove water spots and road film off car glass
    By Mike Phillips in forum Product Reviews by Mike Phillips
    Last Post: 05-21-2017, 12:04 AM
  4. 370z, having issues using griots one step / griots DA
    By ssdx in forum Auto Detailing 101
    Last Post: 04-12-2014, 10:49 PM
  5. Replies: 12
    Last Post: 11-21-2011, 12:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
