Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Newbie Member
    Join Date
    Jun 2008
    Posts
    4
    Post Thanks / Like
    Removing streak marks from Reload after fresh Cquartz
    Just got done putting on two coats of CQuartz on my black CTS. It looked awesome until the next morning before backing out of the garage, when I decided I would top it off with Reload.
    I started with the hood and must not have shaken it before I used it, or didn't purge out the old spray in the nozzle. I did the rest of the vehicle and let if sit before I headed out for lunch. Didn't notice the streaks in the hood at the time. The hood is the only panel that has streak marks.
    So how to correct the streak marks? Once I noticed I tried to top off with more Reload and rebuff, nope. Tried Eraser, nope. At this point, I'm ready to re-do the hood. But what is needed to remove the Reload streaks? I typically use Wolfgang Total Swirl Remover or Finishing Glaze and a Flex 3401. Is it possible just to polish out the streak marks and without removing my two coats of Cquartz, or will polishing remove that too?
  2. #2
    Regular Member
    Join Date
    Apr 2019
    Posts
    162
    Post Thanks / Like
    Re: Removing streak marks from Reload after fresh Cquartz
    polishing may remove some of the cquartz , I would not polish it. Reload is pretty weak itself, have you tried a car wash with a good soap ( reset?) .
    I m not sure on the cure time of cquartz before a car wash though, I thought it was a week last time I check
    If polish is really necessary , I would do a very light hand polish with the least abrasive polish you have or use something like car pro gloss pad with a light polish. But reload is very weak though, it should come out after 1 or 2 car washes , maybe some iron x and eraser.
    You may have to wait for the curing time before a wash, worst come to worst you ll re-do the hood if it doesnt come out
  3. Thanks Craig Encinitas thanked for this post
    Likes luckycarretera liked this post
  4. #3
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,112
    Post Thanks / Like
    Just get a damp mf and wipe. This works with fresh Reload. Don't know if it will work on semi cured Reload.
  5. #4
    Super Member Coatingsarecrack's Avatar
    Join Date
    Dec 2018
    Posts
    7,248
    Post Thanks / Like
    Streaks from Reload should buff out with more reload or damp MF. If it doesn’t streaks may be in your coating
  6. #5
    Super Member Bruno Soares's Avatar
    Join Date
    Mar 2017
    Location
    Southeastern PA
    Posts
    2,482
    Post Thanks / Like
    You could have high spots on the hood and think they’re streaks? Reload is pretty known for streaking on dark color cars but shouldn’t be hard to remove, maybe they’re high spots on the coating.
    If you have leftover everything, polish the hood and coat it again. Then skip Reload.
    Bruno Soares
  7. Likes Craig Encinitas, The Guz liked this post
  8. #6
    Super Member BudgetPlan1's Avatar
    Join Date
    Dec 2015
    Location
    Central OH
    Posts
    2,016
    Post Thanks / Like
    Quote Originally Posted by Rsurfer View Post
    This works well with Sio2 maint products, especially if the microfiber is damp w/ hot water, followed by a buff with dry microfiber.
  9. #7
    Regular Member OMGClayAiken's Avatar
    Join Date
    Jul 2017
    Posts
    105
    Post Thanks / Like
    I had the same thing happen to me - I just waited it out and they were gone after a couple months I think (can't remember exactly how long but it did take a bit of time)
    Sent from my SM-N976U using Tapatalk
  10. Likes The Guz liked this post
  11. #8
    Join Date
    Jan 2007
    Posts
    14,112
    Post Thanks / Like
    Quote Originally Posted by OMGClayAiken View Post
    Some people are not as patient as you. Most want immediate results, including myself.
  12. #9
    Join Date
    Jul 2017
    Posts
    105
    Post Thanks / Like
    Yeah, I just didn't want to so anything that might hurt the coating
  13. Likes Coatingsarecrack liked this post
  14. #10
    Newbie Member
    Join Date
    Jun 2008
    Posts
    4
    Post Thanks / Like
    Thanks for all the advice. I'm 100% sure the streaks are from the Reload. I'll have to wait for a warmer day and make sure the Cquartz is cured before attempting to repair the streak marks.
Similar Threads
  1. Cquartz uk 3.9 and reload
    By Sushi5679 in forum Auto Detailing 101
    Last Post: 05-02-2018, 11:01 AM
  2. Cure time using reload over fresh cquartz standard
    By suke in forum Ask your detailing questions!
    Last Post: 04-12-2017, 03:23 PM
  3. reload then Cquartz UK
    By skip62 in forum Ask your detailing questions!
    Last Post: 03-12-2015, 08:31 PM
  4. Reload over CQuartz DLX?
    By MarkD51 in forum Auto Detailing 101
    Last Post: 06-21-2014, 06:15 PM
  5. Cquartz and reload
    By jamores23 in forum Auto Detailing 101
    Last Post: 01-29-2012, 12:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» June 2024
S M T W T F S
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
