Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    Super Member swanicyouth's Avatar
    Join Date
    Mar 2011
    Location
    Limerick, PA
    Posts
    9,388
    Post Thanks / Like
    Wheel Wells: Undercoating or Paint?
    I'm looking for something to cover the grey-brown metal under my wheel wells - this is the part that isn't covered with plastic on a SUV.
    Its clean under there. I'm thinking of using undercoating, because I just can't see spray paint lasting long. Usually I clean my wheel wells with a pressure washer, and I'm wondering if undercoating would just get blasted away?
    Any experience here?
    Any brands of undercoating that harden up and stick well?
    AG sells Sprayaway Undercoating for $6... The 3M stuff is almost $20 locally. Is there a difference?
  2. #2
    Super Member Becciasm's Avatar
    Join Date
    Jul 2009
    Location
    Virginia Beach, VA
    Posts
    1,066
    Post Thanks / Like
    Roll on or paint on bed liner. Duplicolor kit at advance, or similar.
    Sent from my VS840 4G using AG Online
    I believe in becoming who I am (Translation: You learn everyday.)
    <-Bubba
  3. #3
    Super Member Chris's FX4's Avatar
    Join Date
    Sep 2011
    Location
    Houghton, MI & Chicagoland
    Posts
    2,089
    Post Thanks / Like
    Re: Wheel Wells: Undercoating or Paint?
    I used the 3M Professional Grade Rubberized Undercoating in the rear wheel wells on my old truck. Finished to a semi smooth finish but still had some texture. Held up really well in the 3.5-4 years it was on there. Didn't peel or crack, got a little dirty kind of like Line-X but cleaned easily. Held up perfectly fine to power washing, and the winters and roads of northern Michigan.
    Will be putting it on the rear wheel wells of the new truck before winter hits.
    2011 Ford F-150 FX4 5.0L -- My Flickr Page
  4. #4
    Super Member Wes Bremec's Avatar
    Join Date
    Jan 2012
    Posts
    473
    Post Thanks / Like
    Okay here is the problem with using any kind of coating underneath the vehicles. If any moisture gets stuck behind the coatings it could potentially cause damage where you are not visibly able to see it. This damage I am referring to is potential rust problems due to moisture being trapped underneath the coating itself. I would trust penetrating oils all day everyday underneath my vehicle rather then paint or and undercoating. I got this friend down the street that has been spraying his own penetrating oil brew underneath vehicles for over 50 years. It works because he has got a car that has been threw 12 cleveland winters with not one spot of rust damage.
Similar Threads
  1. Heavy Tar and Road Paint in Wheel Wells
    By dnoraker in forum Auto Detailing 101
    Last Post: 12-12-2014, 05:13 PM
  2. Replies: 2
    Last Post: 08-29-2013, 08:06 PM
  3. Road paint in wheel wells
    By Wayneezy in forum Auto Detailing 101
    Last Post: 08-19-2012, 05:55 AM
  4. Road paint in the wheel wells...
    By DaGonz in forum Auto Detailing 101
    Last Post: 07-20-2011, 02:09 AM
  5. how to get rid of splatter paint under wheel wells
    By nabisco shine in forum Auto Detailing 101
    Last Post: 08-14-2010, 07:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
