Dislikes: 0
Dealing with oxidation spots
I've got a 12" x 6" spot on my wife's 2006 Highlander (dark blue metallic) on the hood that is dull and appears to be oxidation. It's not a milky-white appearance, just dull with a non-slick surface. I was able to get the dullness out to about 80% using a DA with Jescar CC with a MF pad. No blue paint on the pad. Calling it good enough, I finished the car with Sonax PF and topped with Ultra Lock Plus. In the end, the area in question was slightly less glossy vs. the rest of the car and the spot felt "slick". I allowed the ULP to "cure" for about 18 hrs overnight. Fast forward to the next day, the spot is dull again and the surface does not feel slick anymore. The rest of the car looks great and feels slick. On a side note, my wife drove it in 95 degree sunshine the next day. Was the heat a factor? I'm thinking maybe the ULP did not cure properly, but the rest of the car is fine. Is the oxidation beyond repair? Could it be something other that oxidized paint?
Super Member
Re: Dealing with oxidation spots
Clear starting to fail would be my guess, based on that info. Maybe 2black1s will see this and chime in...as he used to be in the autobody bussiness
I’m with Opie on the likely cause unfortunately and there really isn’t anything to be done other than repaint.
Ok, thanks for the feedback. Overall the car looks decent- at least I was able to remove the majority of defects from almost 20 years of drive-through washes. And, my wife is happy so its a win!
Super Moderator
Sounds like early stages of clear coat failure. Just keep it protected the best you can until the hood can be repainted. It's pretty common to see on older Toyota's with metallic paint finishes.
Super Member
Similar Threads
By ethorpe1588 in forum Auto Detailing 101
Last Post: 01-21-2016, 02:10 AM
By mikesal57 in forum Auto Detailing 101
Last Post: 07-28-2013, 04:52 PM
By swanicyouth in forum Auto Detailing 101
Last Post: 03-19-2013, 07:10 PM
By m3barry in forum Auto Detailing 101
Last Post: 06-15-2011, 09:36 PM
By GaryD in forum Ask your detailing questions!
Last Post: 08-08-2010, 05:14 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
