Dislikes: 0
Super Member
First time w/Fuzion
Should fuzion be used by itself? I've read through the desciption a couple times. It has some of the properties of the DGPS. Usually I'll use the DGPS and then souveran or P21S 100%. Just curous. Thanks
Junior Member
Re: First time w/Fuzion
I would put sealant first then add Fuzion I guess to help it bond to the sealant better.
Super Member
I would suggest using Fuzion alone first to see the true results. You can always add a sealant under it later if you feel you need more durability.
Super Member
I've only seen it used alone and it was impressive.
Super Member
I Used It 3x Alone And It Looks Better Every Application
Super Member
always use the sealant first. if you use crappy wax then use the sealant, it (the sealant) will give out way too soon. Things you learn on this board and my bimmer forums.
Example:
Klasse AIO
SG
P21S wax
I would use it alone and test its durability.
Super Member
I used the WG Spray Sealant and then the Fuzion in June and WOW, I still get comments on how wet it looks and the car is White I was advised the Sealant should be applied for protection and the Fuzion for a warmer deeper shine. I couldn’t be happier.
Similar Threads
By jamesalanb in forum Auto Detailing 101
Last Post: 10-25-2013, 10:40 PM
By DRamsey in forum Auto Detailing 101
Last Post: 02-10-2013, 05:47 PM
By Emm in forum Product Reviews
Last Post: 09-06-2010, 09:58 AM
By Billd0957 in forum Auto Detailing 101
Last Post: 06-28-2009, 10:50 AM
By Meghan in forum Auto Detailing 101
Last Post: 08-25-2008, 06:45 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
