Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Super Member richy's Avatar
    Join Date
    Mar 2007
    Location
    Windsor, Ontario
    Posts
    5,158
    Post Thanks / Like
    hardened tree sap
    The last car I did had a glob of hardened tree sap on the back bumper's upper edge, which is only about 3.5 or 4" wide. The clay (I tried 2 different ones) wouldn't do it. Wet sanding wouldn't do it. I couldn't get that bloody blob off! Then I tried a straight razor blade and kept skimming layers off until I got right down to the paint. Bottom line? Completely gone and no trace! Just wanted to share
  2. #2
    Super Member AUdakota's Avatar
    Join Date
    Jan 2007
    Location
    Auburn, AL / Nashville TN
    Posts
    714
    Post Thanks / Like
    i had that problem one time and I decided to let the pressure washer sit on it and low and behold it came right off, along with about 1 square inch of paint off my fender flares
    Frank
    Thanks to AG I only wipe my butt with MF's now
  3. #3
    Super Member ScottB's Avatar
    Join Date
    Mar 2006
    Location
    South Florida
    Posts
    18,803
    Post Thanks / Like
    I soak it for two-three minutes with some Poorboys Bug Squash and then it usually just pops right off.
    Scott
  4. #4
    Regular Member White95DodgeRam's Avatar
    Join Date
    Sep 2006
    Location
    El Paso Texas
    Posts
    181
    Post Thanks / Like
    very good info to know i was wondering how id get the pine sap off my 78!
  5. #5
    Super Member turbos17's Avatar
    Join Date
    Dec 2006
    Location
    Downey (Southern), CA
    Posts
    511
    Post Thanks / Like
    Turtle Wax's -Bug and Tar Remover! That stuff is amazing! Plus it is an OTC product!
    2005 Toyota Tacoma Pre-Runner
    aka "Storm Trooper"
    "Car waxes and paint sealants are to men like shoes are to women, you can never have too many" - Mike Phillips
  6. #6
    Super Member Jimmie's Avatar
    Join Date
    Dec 2006
    Location
    Upper Desert, CA
    Posts
    4,349
    Post Thanks / Like
    A friend of mine had some sap on his BMW for at least two months. He came over last week and we got it off with two apps of "Stoners Tarminator". It looks like it disolves it. After the first app it was a smaller blob.
  7. #7
    Newbie Member
    Join Date
    Apr 2007
    Posts
    3
    Post Thanks / Like
    Denatured alcohol works great for me. It cleans up tree sap, most grease stains as well as disinfects. I found it pretty safe on just about anything and it evaporates almost instantly. I keep a gallon can of it around the house for lots of different cleaning projects.
  8. #8
    Join Date
    Mar 2007
    Location
    Windsor, Ontario
    Posts
    5,158
    Post Thanks / Like
    Quote Originally Posted by mongo22
    Is that the same as Isopropyl alcohol? I have some 50/50 mix of that.
  9. #9
    Newbie Member
    Join Date
    Apr 2007
    Posts
    3
    Post Thanks / Like
    Denatured alcohol and Isopropyl alcohol (rubbing alcohol) are very simular and will both remove tree sap. I happen to use denatured because we use it at work alot for prepping surfaces to be masked off for painting. This is mostly latex (water ) based paints. Ive been a house painter and faux painter for many years so Ive allways had gallons of denatured alcohol, paint thinner and lacquer thinner around. You can buy it at any paint store or Home Depot and Lowes type places.
    Another great use for denatured alcohol is removing hardened latex paint. If you have any splatters or extra paint on surfaces you dont want, it will soften it and you can clean it up without hurting the surface underneath. Im allways finding a new use for that stuff! So, yes Isopropyl alcohol will remove tree sap quite well but you might want to use it full strength on some of the more hardened spots.
  10. #10
    Junior Member
    Join Date
    May 2007
    Location
    L.A. Canada
    Posts
    75
    Post Thanks / Like
    I was at a local automotive store today and they sold me some "alcohol stove burning fuel "Methyl Hydrate" (99.9% pure)" is this the same as isopropyl alcohol?
    And does anyone wanna tell me that its ok to go putting on any kind of car paint without doing any harm?? (even older paint such as 15 year old paint)
    Also what are all of its uses? Cleaning tar/sap and old wax etc. off of the surface? Or to check if a product you just used contains any fillers and only hid the blemish instead of corrected it? Any others?
Similar Threads
  1. removing hardened pin stripe tape
    By bama16 in forum Ask your detailing questions!
    Last Post: 01-12-2021, 01:51 PM
  2. Hardened construction adhesive
    By Doninvt in forum Auto Detailing 101
    Last Post: 10-26-2020, 09:57 AM
  3. Hardened gorilla glue
    By Kams229 in forum Ask your detailing questions!
    Last Post: 03-24-2014, 10:51 PM
  4. Remove black hardened tar like goo?
    By jyu1210 in forum Auto Detailing 101
    Last Post: 09-07-2012, 07:44 PM
  5. Removing hardened tree sap
    By emaxxman in forum Auto Detailing 101
    Last Post: 04-13-2006, 09:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» June 2024
S M T W T F S
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
