Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Regular Member
    Join Date
    Oct 2013
    Posts
    141
    Post Thanks / Like
    Cleaning microfiber drying towels
    Hi all
    I’ve recently purchased some Microfiber Madness Dry Me Crazy towels where after a couple of maintenance washes it has picked up some light dirt from some spots under the doors.
    What would be the best and easiest way to clean or wash these drying towels?
    Thanks
  2. #2
    Junior Member
    Join Date
    Mar 2018
    Posts
    80
    Post Thanks / Like
    Re: Cleaning microfiber drying towels
    You could try spot cleaning and soaking with a microfiber cleaning detergent before throwing it in the wash again.
  3. #3
    Newbie Member Robert Feldman's Avatar
    Join Date
    Jun 2018
    Posts
    4
    Post Thanks / Like
    I regularly pre soak the dirty spots on my drying towels with SHOUT! Let the towels absorb the pre soak for at least an hour before washing. Works like a charm for me!
  4. Likes Dr Oldz liked this post
    Dislikes Dr Oldz disliked this post
  5. #4
    Super Member
    Join Date
    Sep 2017
    Location
    Sweden
    Posts
    3,022
    Post Thanks / Like
    Get some 3D Towel Kleen it's a mf detergent. And wash the drying towels after each use to be certain to it has not picked any dirt up. That would scratch your paint more than necessary. And don't use any fabric softerner of any kind. You could use once in a while a little white vinegar in the rinse cycle. Read the description of the drying towel if they recommend to dry it in the dryer on low heat. And what setting on the washer they recommend. If you have trouble with getting a stain off the drying towel. You could mix up a spray bottle with 1:10 dilution of 3D TK and spray it on and let it soak for 5-10min. Or you make a bucket with 3D TK solution and let it sit in there for a longer time. I don't like the chemicals to dry on what ever I use it for. As that's when the damage accurs. If you have it in a bucket lift it up once and a while and wring it out over the bucket and put it in there again.
    3D Towel Kleen
    /Tony
  6. Thanks cheekyage thanked for this post
    Likes cheekyage liked this post
  7. #5
    Super Member Coopers ST's Avatar
    Join Date
    Nov 2013
    Location
    Firestone, CO
    Posts
    1,268
    Post Thanks / Like
    Quote Originally Posted by SWETM View Post
    3D Towel Kleen
    /Tony
    I used to think microfiber detergent was a gimmick, just something else to nickel another $20 out of us once a year. I was having an issue with towels not being as absorbent as they once were and thought what the heck it would be cheaper than a bunch of new towels and it still wouldn't be wasted just maybe not as good as all free and clear.
    Well 3D towel clean works. The towels come out fluffier than before, feel different, are softer, look cleaner, and dries like new again. Not sure if other brands work as well or better, but this stuff works and isn't a gimmick.
    ​1991 BRG Miata
    Brad's Detailed Touch
    https://www.facebook.com/Bradsdetailedtouch1
  8. Thanks SWETM, cheekyage thanked for this post
    Likes SWETM, cheekyage liked this post
  9. #6
    Super Member
    Join Date
    Apr 2016
    Location
    Toronto, Canada
    Posts
    307
    Post Thanks / Like
    I wash my all my MF products towels the same way.
    I put them in the washing machine on warm, add some 3D Towel Kleen, then put them in the dryer on low.
    This process seems to work well for me.
  10. Likes SWETM, cheekyage, Misterpaul liked this post
  11. #7
    Regular Member
    Join Date
    Oct 2013
    Posts
    141
    Post Thanks / Like
    Thanks guys.
    Do I use cold or hot water if I wash in the washing machine?
    Same with spot cleaning too.
  12. #8
    Regular Member
    Join Date
    Jun 2017
    Posts
    187
    Post Thanks / Like
    Quote Originally Posted by derass View Post
    I do this as well, zero issues.
    Sent from my SM-G955U using Tapatalk
  13. #9
    Super Member UncleDavy's Avatar
    Join Date
    Aug 2017
    Location
    Taunton, MA
    Posts
    1,589
    Post Thanks / Like
    Quote Originally Posted by cheekyage View Post
    Thanks guys.
    I would use warm or cold water for washing. Hot water just like high heat in the dryer can melt or damage the microfibers.
  14. #10
    Regular Member
    Join Date
    Jun 2017
    Posts
    187
    Post Thanks / Like
    Quote Originally Posted by UncleDavy View Post
    To add to this. I've made the mistake a few times leaving the water or dryer on high. The only towels I noticed a differnece on were my plush edgeless towels. I was able to get the roughness to go away by washing them again and adding vinegar to the bleach dispenser.
Similar Threads
  1. How to revive microfiber drying towels?
    By Eldorado2k in forum Auto Detailing 101
    Last Post: 01-27-2021, 08:14 PM
  2. Drying microfiber towels
    By Icarus in forum Auto Detailing 101
    Last Post: 10-07-2019, 01:59 PM
  3. Microfiber towels for washing and drying...
    By Lexi65 in forum Auto Detailing 101
    Last Post: 03-30-2014, 05:39 PM
  4. When washing - drying my microfiber towels
    By keeganjacobs in forum Ask your detailing questions!
    Last Post: 03-23-2014, 04:39 PM
  5. Microfiber Drying Towels - Best and Boiling Towels
    By MI Mike in forum Auto Detailing 101
    Last Post: 03-27-2010, 05:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
