![Thanks](https://www.autogeekonline.net/forum/dbtech/thanks/images/thanks.png) Thanks: 0
![Likes](https://www.autogeekonline.net/forum/dbtech/thanks/images/likes.png) Likes: 0
![Dislikes](https://www.autogeekonline.net/forum/dbtech/thanks/images/dislikes.png) Dislikes: 0
Thin single stage paint questions - 1987 Volvo 240
Thin single stage paint questions?
I have a 1987 volvo 240 with some very poor paint. I stumbled upon this link https://www.hemmings.com/stories/201...le-stage-paint and read through it a few times and decided to give it a try.
I have a griots garage synthetic clay pad, a bottle of #7, and a bottle of mothers CMX ceramic coating in place of waxing at the end.
So far, I have clayed most of the car and I'm pretty happy with my results, however I still have some contaminants like bird poop stains that I haven't been able to remove along with bad swirling.
Based on the instructions from my link, next I should clean the paint (once I'm done claying), however I don't know my paints condition and I'm not too confident in it because of a few spots that are rubbed down past paint so I planned on going straight to #7 saturation.
What are my options here?
I'm trying to stick to a budget here and just want my paint to look pretty good for as long as possible.
1: Should I keep claying in the hopes of getting all of the contaminants out or is it a lost cause,
2: And will #7 help with paint swirls if I can't confidently otherwise clean the paint?
Re: Thin single stage paint questions
Since this is your first post to the forum,
Welcome to AutogeekOnline! ![Welcome](https://www.autogeekonline.net/forum/images/smilies/welcome.gif)
Hope you don't mind I edited your post and turned one large chunk of text into something easier to read and then answer.
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by tog244
Here's the link to the above article on our forum. The couple in the article basically read my original article on how to restore antique and original single stage paint, followed my recommendations and the rest as the saying goes is history.
Detailing tips for vintage single-stage paint - by Steve Berry at Hemming's Motor News Blog
![](http://www.autogeekonline.net/gallery/data/722/1971_Volvo_003.jpg)
The Griot's Synthetic Clay Pad, (a polymerized rubber with abrasives in it), is only good for removing "above surface bonded contaminants".
For any type of paint defects below or IN the paint - you would need to ABRADE the paint with a compound, polish or AIO - something with abrasives in it.
No. See what I wrote above.
#7 is a water soluble oil that uses Meguair's trade secret oils that have the ability to bring out and/or restore the full richness of color in the pigments of single stage paint.
It will not remove defects like bird poo stains or swirls and scratches. If you rub enough the oil plus the "material" you rub with can abrade the paint and level it a little bit helping to improve the appearance of below surface defects but using a true, dedicated compound, polish or one-step cleaner/wax, (an AIO), will do more to remove swirls, scratches, water spots and oxidation.
Can you share a picture? If possible - e-mail it to me and I'll share it for you and sharing pictures on a "forum" tends to be a tick difficult.
Mike.Phillips@autogeek.net
Thanks for all of the information, I really appreciate it! I will email you some pictures- its pretty rough though. I'm worried that polish or compound will eat right through my paint as there doesn't seem to be much, so would you recommend skipping it and just biting the bullet that the paint isn't going to be perfect or should I try and get it perfect (so to speak). I have no doubts that it will be vastly improved, however I would hate to get it 90% of the way there and ceramic coat it if its possible to get it better.
No problmo... that's what we do around here --> information. ![cheers](https://www.autogeekonline.net/forum/images/smilies/cheers.gif)
Here's the pictures. At full size these were 3024 pixels wide by 4032 pixels tall and weighed in at 1.55 megabytes. In other words, HUGE picture files. I've resized to 600 pixels wide and then uploaded to your free gallery here on AutogeekOnline. I also renamed them to Volvo.001, Volvo.002, Volvo.003, Volvo.004, Volvo.005 - to make them easier to work with on the line.
![](http://www.autogeekonline.net/gallery/data/500/Volvo_0011.jpg)
![](http://www.autogeekonline.net/gallery/data/500/Volvo_002.jpg)
![](http://www.autogeekonline.net/gallery/data/500/Volvo_003.jpg)
![](http://www.autogeekonline.net/gallery/data/500/Volvo_004.jpg)
![](http://www.autogeekonline.net/gallery/data/500/Volvo_005.jpg)
Yup.
Yup.
Yup.
I would rub the paint down with Meguair's #7 a few times and the seal it with either an old school Carnauba wax like Collinite 845 or Meguiar's M20 Polymer Sealant and then stick a fork in it, call it good and kick it out the door.
If you rub this paint down with Meguiar's #7 it's going to be funky trying to then install a conventional ceramic coating, (the kind that typically comes in a tiny glass bottle), BECAUSE part of prepping the paint for this type of coating is to use a PANEL WIPE, (a panel wipe is a SOLVENT), and the panel wipe will CHEMICALLY STRIP THE PAINT - or in other words, REMOVE the #7 oils and likely make the paint look DULL - before coating it, thus doing what I call,
Working backwards
A better option to me would be to rub the paint down 2-3 times with the #7 and these really nice #7 towels from Griot's Garage,
Meguiar's Mirror Glaze #7 Show Car Glaze
Griot's Garage PFM Wax Removal Towel - 4-pack
Then instead of using a conventional ceramic coating, do this instead - use the 303 Graphene Nano Spray Coating.
Here's my review on this product,
Review: 303 Graphene Nano Spray Coating
![](http://www.autogeekonline.net/gallery/data/4183/303_graphene_001.JPG)
Here's how I apply it and recommend to others to apply it - INCLUDING getting the orange Rag Company towels I show, use and recommend.
Recommendation: Microfiber Applicator Pad for applying 303 Graphene Nano Coating Spray
Extra Large Microfiber Applicator Pad
![](http://www.autogeekonline.net/gallery/data/722/Best_303_Applicator_00.JPG)
Mike Like - The Rag Company FTW Premium Orange Microfiber Towel
![](http://www.autogeekonline.net/gallery/data/4244/FTW_Premium_Orange_Microfiber_Towels_001.JPG)
I believe based upon years of real-world hands-on experience working on single stage paint - the products and process I've listed will enable you to take the paint on this Volvo to its maximum potential while also preserving as much of what's left as possible.
Abrading it with an abrasive polish could be done on the vertical panels, but for the horizontal panels, rubbing the paint down a few times with the #7 and the the Griot's PFM Wax Removal towels, the TOWELS will be your ABRASIVE and the Trade Secret Oils in the #7 will GENTLY restore what's left of this old, thin, brittle dry paint.
That's what I would do.
With paint like this you really need to take the 30,000' point of view or what I call,
The BIG PICTURE
Outside of repainting the car, the most you can do is the most you can do and the most you can do is bring some life back to what's left and that's where the #7 excels for vintage paint. The oils in the #7 have the unique characteristic of restoring the full richness of color to the PIGMENTS. That's how it works.
Here's my article on this topic,
"Taking your car's paint to it's maximum potential"
Here's another article I wrote for our industry,
Paint Condition Categories
The paint on your Volvo falls into catagory #7 Extreme Oxidation
It might also be category #9 Unstable - but you won't know until some time passes after the #7 rub down.
And if the red paint fades back to dull after the #7 rub down after a few weeks go by, then the paint is category #11 - Paint the Point of No Return.
But... you don't know what you can do until you try.
Last post...
My good friend Kirby, also an alumni student after taking 3 of my car detailing classes, recently shared this project.
Meguiar's No.7 Glaze for Single Stage - Bondo?
In post #3 of the above thread, I shared what I think is the most important aspect of these types of projects and that's getting GREAT before shots.
Why?
Because AFTER you do the paint restoration - you can NEVER go back in time to get the before shots as it will be too late. And it's the BEFORE shots that create the POWER in the AFTER shots.
From 2009
The power in the after shots is created in the before shots
Hope all of the above helps...
Similar Threads
By wrr1020 in forum Ask your detailing questions!
Last Post: 11-20-2018, 07:44 PM
By wrr1020 in forum Auto Detailing 101
Last Post: 11-10-2018, 04:54 PM
By fst89lx in forum Auto Detailing 101
Last Post: 08-16-2013, 07:15 PM
By sillybinaries in forum Products Guides
Last Post: 02-24-2013, 02:26 PM
By walt in forum Ask your detailing questions!
Last Post: 05-25-2011, 05:26 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
26 | 27 | 28 | 29 | 30 | 31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
