Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 3 of 3
  1. #1
    Super Member Nix's Avatar
    Join Date
    Jun 2015
    Posts
    297
    Post Thanks / Like
    Need some advise..
    I am looking for some long term sealants and i came across these..BLACKFIRE Crystal Coat Paint Coating
    Detailer’s Paint Coating, nano paint sealant, ceramic paint coating, nano paint coating
    has anyone tried them and which one do you recommend..this will be my first time detailing and according to autogeek " While not as easy to apply as DP Paint Coating or Optimum Gloss-Coat, BLACKFIRE Crystal Coat is definitely worth the extra effort because it protects your vehicle's paint the best."
    so which one should i get..i usually dont have much time for detailing so looking for something bit long term than 3 to 4 months..car will be garaged during the night daytime its outside..
  2. #2
    Super Member wdmaccord's Avatar
    Join Date
    Jun 2013
    Location
    West Des Moines, IA
    Posts
    1,278
    Post Thanks / Like
    Re: Need some advise..
    search the forum and/or youtube. Both have info. Also, it is a coating, not a sealant.
    2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
    2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
    2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
  3. #3
    Super Member ski2's Avatar
    Join Date
    Dec 2011
    Location
    Southwest PA
    Posts
    1,826
    Post Thanks / Like
    If this is your first time detailing IMO you shouldn't be applying a coating. For the coating to look good the finish needs to be in excellent condition--this means machine polishing. Secondly the finish needs to be absolutely squeaky clean for the coating to bond and thirdly you need to smooth out the high spots at the right time. If you mess up the coating application the only way to remove it is by polishing off with a machine.
    There are many sealants out there that will last at least 6 months and are much more forgiving. Some are WOWA (wipe on walk away) which would give you some practice at the technique you need to use applying a coating, which you can always do once you are more experienced.
    Spend some time here reading to get a handle on the products and techniques you will need.
Similar Threads
  1. Need some advise
    By LAD in forum Auto Detailing 101
    Last Post: 06-12-2015, 04:45 PM
  2. advise???
    By fq_22 in forum Auto Detailing 101
    Last Post: 08-06-2014, 09:15 AM
  3. Need advise!!!
    By pursuit 2550 in forum Auto Detailing 101
    Last Post: 07-24-2014, 09:24 AM
  4. Need some Advise!
    By IvanDRios in forum Auto Detailing 101
    Last Post: 09-09-2008, 04:23 PM
  5. Some advise, if you please
    By don04 in forum Auto Detailing 101
    Last Post: 03-13-2008, 06:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
