Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
  1. #1
    Super Member SPIROS ANTONIOU's Avatar
    Join Date
    Nov 2010
    Location
    CYPRUS
    Posts
    274
    Post Thanks / Like
    cyclo PROGUARD ORBITAL BACKING PLATE
    hello folks
    I HAVE A QUESTION FOR ALL YOU CYCLO USERS.
    I HAVE SEEN THESE THREAD PROGUARD ORBITAL BACKING PLATE.
    THROUGH MY RESEARCH ON THESE PLATES I UNDERSTANT THAT YOU USE THESE INSTEAD OF THE RUBBERBOOTS. IAM RIGHT?
    2.DID ANYONE OF YOU USE DIFFERENT PADS THAN THE ORIGINAL CYCLO PADS?CAN I USE WOOL PAD ON THESE ?ANY SUGGESTIONS
    sorry for my english
    Amateur between pros
  2. #2
    Administrator Jason's Avatar
    Join Date
    Mar 2006
    Posts
    354
    Post Thanks / Like
    Re: cyclo PROGUARD ORBITAL BACKING PLATE
    Yes the proguard are to be used instead of the rubber boots. You can use any type of pad as long as its 4 inches.
    "The true spirit of conversation consists in building on another man's observation, not overturning it." Edward G. Bulwer-Lytton
  3. #3
    Super Member tuscarora dave's Avatar
    Join Date
    Aug 2009
    Location
    Etters PA
    Posts
    5,403
    Post Thanks / Like
    I have seen these new backing plates but haven't tried them because I replaced the rubber boot ones with Lake Country 3 3/4" backing plates for the PC. I highly suggest that you go with the LC ones. IMO they are of the best quality, however I would suggest sticking with Genuine Cyclo Pads because they last 100 times longer than other 4" pads. You can buy Genuine Cyclo wool pads in a few different levels of cut. They are very nice wool pads, I even use them on my rotary polisher.
  4. #4
    Join Date
    Nov 2010
    Location
    CYPRUS
    Posts
    274
    Post Thanks / Like
    Quote Originally Posted by tuscarora dave View Post
    As i said in my previous posts i am from cyprus and the shipping cost are very high .Can you suggest me what kind of wool pads i shall order because i dont want to waste my money.
  5. #5
    Join Date
    Aug 2009
    Location
    Etters PA
    Posts
    5,403
    Post Thanks / Like
    Quote Originally Posted by SPIROS ANTONIOU View Post
    If you are using a Cyclo and want wool pads, these are the only ones I can recommend.
    Cyclo 4 Inch Wool Pads, hook and loop wool pads, wool cutting pads
    For foam pads these are the only pads as anything else will fall apart rather quickly.
    Cyclo 4 Inch Premium Foam Pads fit on each head of your Cyclo Dual Head Orbital Polisher
    If shipping is an issue and you intend on doing lots of work with your Cyclo I would recommend getting at least ten of each pad. That should last you a year or longer.
Similar Threads
  1. Replies: 25
    Last Post: 10-07-2021, 02:58 PM
  2. Griots 6” random orbital- why 6” backing plate?
    By 1k9 in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 03-06-2018, 01:03 AM
  3. Replies: 0
    Last Post: 09-02-2017, 08:14 PM
  4. Griots 3" Heavy Duty Orbital Backing Plate Review
    By Heisenberg in forum Product Reviews
    Last Post: 04-07-2017, 06:31 PM
  5. Griots 6" backing plate VS. Lake Country's backing plate
    By ryanmcg1 in forum Product Reviews
    Last Post: 09-29-2011, 11:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
